I have a string which I'd like to parse into something meaningful i.e keys & values
The structure of it is a little weird in that it has a couple of lines as the header for each section, which seem to be a repeat of the info in that section. In the sample below, there are 2 sections, beginning with the lines:
- Predicted class name: truck
- Predicted class name: excavator
I really just need the 'display_name' and 'score' fields
- {display_name: "truck", score: 0.9870228171348572}
- {display_name: "excavator", score: 0.9359530210494995}
I've tried various nodes, including functions- but if someone could point me in the right direction, I'd be very grateful
Predicted class score: 0.0
[annotation_spec_id: "481228201931046912"
image_object_detection {
bounding_box {
normalized_vertices {
x: 0.8229872584342957
y: 0.5793604850769043
x: 0.9742650985717773
y: 0.6732610464096069
, annotation_spec_id: "2041373629094035456"
bounding_box {
x: 0.005605409853160381
y: 0.5414829254150391
x: 0.1891111582517624
y: 0.7010807991027832
bounding_box {
bounding_box {
thanks
Andrew
There’s a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path to any data item.
Hi @zenofmud
thanks for the quick reply..!
I should have made it clearer- the basic problem is that my data is just one big string.
It's not like JSON or an array where you can get the path etc
There are some lines outside of the square brackets
but thanks for the link- I'll have a look through it
can you copy the value (using the copy value button that appears under your mouse when you hover the debug value) & paste it as code (use the forums </> code button)
I'm confused looking at your data and what you say the output should look like.
You say the first output whould be
but the data is:
How do you know what score goes with what? And should it be based off the 'display_name' or the 'Predicted class name'?
TBH, it looks like wherever that data is coming from (I'm guessing a python program) should really be modified to send clean/proper JSON.
Do you have access to the source program - a far better fix is to produce good JSON instead of parsing this tangle of strings. I'm not saying it isn't possible (you could very will split by line, remove brackets [ { } ], split by :, trim each value, parse the data type to a number, string or object & loop through it all) - just not ideal!
Hi Steve
I think this is what I did in my first post- but I've done it again to be sure
NR seems to display the line break symbols in the debug window & when you click the output, or copy/paste, it is displayed with the lines
thanks
bounding_box {
bounding_box {
bounding_box {
bounding_box {
Hi Steve,
This data is just what a Google API spits out- I have queried it with Google- response pending
This is the API Package google.cloud.automl.v1 | Cloud AutoML Documentation | Google Cloud
There are some input parameters to filter results (such as 'score_threshold', but as far as I can establish, nothing that determines the output format
thanks
Andrew
Could you share a minimal flow that results in this data?
E.g. no dashboard or custom nodes other than the node that you use to communicate your input to GC - use inject or change nodes to prepare the call to GC etc.
