Object vs strings - extract a value from a split
Hi there, beginner warning!
I have this flow working fine to extract the humidity value from a string:
[{"id":"879a195a.741c98","type":"inject","z":"5996dc31.f79034","name":"{\"status\":\"ok\",\"humidity\":\"53\"}","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"status\":\"ok\",\"humidity\":\"53\"}","payloadType":"str","x":460,"y":420,"wires":[["6e2e795d.9d47e8","715c958a.e0077c"]]},{"id":"715c958a.e0077c","type":"debug","z":"5996dc31.f79034","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":970,"y":420,"wires":[]},{"id":"6e2e795d.9d47e8","type":"function","z":"5996dc31.f79034","name":"Extract humidity","func":"var IN = msg.payload.split(\"\\\"\");\nvar HUMID = parseInt(IN[7]);\nvar msg1 = {payload:HUMID};\nreturn [msg1];","outputs":1,"noerr":0,"initialize":"","finalize":"","x":740,"y":480,"wires":[["715c958a.e0077c"]]}]
But the node giving me the values is outputting an object...
msg.payload : Object
{ status: "ok", humidity: "53"
I have no clue how to modify this code:
var IN = msg.payload.split(""");
return [msg1];
from an object.
Now I get this error:
function : (error)
"TypeError: msg.payload.split is not a function"
You need to understand the differnece (and advantage) of using objects and properties in node-red (and JavaScript in general).
For example, if you have an object, there is ZERO need to split strings etc.
JSON stands for JavaScript Object Notation - meaning it is a string representation of a JS object - which is useful for transmitting between devices and across the internet (they all do strings right!). That is why JSON is so popular - because it is REALLY EASILY convert to/from object/string.
So, when your data is a string, you have to split and mess about with it. Worse still if you want to change a value.
So the simple way to deal with JSON strings is to use a JSON node to convert the JSON string to a JS object. Or in you case, switch the inject to JSON mode ...
--- ↑ change to ↓ ---
then it is childs play grabing (or changing) any of the values you want...
I recommend watching this playlist: Node-RED Essentials. The videos are done by the developers of node-red. They're nice & short and to the point. You will understand a whole lot more in about 1 hour. A small investment for a lot of gain.
As Steve said you need to understand JSON and objects. Read his links and watch the videos.
Your inject feeds in a JSON string, while you say "the node givving me the value" is giving you an object. So i change your inject node to feed in an object.
You can then target/address the path to an object value. I show an example in the function node.
[{"id":"879a195a.741c98","type":"inject","z":"5a245aa1.510164","name":"{\"status\":\"ok\",\"humidity\":\"53\"}","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"status\":\"ok\",\"humidity\":\"53\"}","payloadType":"json","x":220,"y":2580,"wires":[["6e2e795d.9d47e8","715c958a.e0077c"]]},{"id":"6e2e795d.9d47e8","type":"function","z":"5a245aa1.510164","name":"Extract humidity","func":"msg.payload=parseInt(msg.payload.humidity);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":460,"y":2640,"wires":[["715c958a.e0077c"]]},{"id":"715c958a.e0077c","type":"debug","z":"5a245aa1.510164","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":690,"y":2580,"wires":[]}]
But definately try to get a understanding of JSON and objects and how to find the path to an object properties using the debug panel.
This post should help to clarify Javascript objects and JSON.
Wow! I'm impressed. Thanks!
Works like a charm! Thanks again
