Parsing ASCII Text - Resolved
I am receiving data formated as ASCII text as follows:
65,90,58,49,50,57,46,57,13 ; which means AZ:129.9
Using the Node-Red "text" ui node, it converts the message code to decimal as shown above. Good.
I want to use the same data to input into a ui gauge, so I need to strip away the "AZ:" portion of the message.
I am a novice Node-Red user.
What are the ways parsing can be done?
Alan
Can you pass a message containing that data to a debug node and then share a screenshot of the message? That will help us determine exactly what you've got and from that, how best to convert it to a proper JavaScript string you can start extracting bits from.
Thanks, Nick.
Here is the screenshot. I expanded two of the messages so you can see how Node-Red is handling the object.
Alan
Alan
Try in a Function node
msg.payload = msg.payload.toString()
return msg
and feed that into a debug node and check it gives you "AZ:129.9". If so then feed that into JSON node which should convert it from a JSON string to a javascript object. Again check in a debug node that you get {AZ: 129.9}. If so then you can reference the value as msg.payload.AZ in the gauge node.
No it won't - AZ:129/9 is not valid JSON.
@n61ab once you have the String, you can use the various JavaScript String functions to split it up as you require - String - JavaScript | MDN
I was confused there by the fact that you have 129/9 instead of 129.9, but I see what you mean. The string needs to be surrounded by { } to be JSON.
@n61ab use this in the function node instead, to make it valid JSON
msg.payload = "{" + msg.payload.toString() + "}"
return msg
@Colin that still isn't valid JSON - the AZ would need to be in quotes - "AZ". Forcing it into a JSON format isn't worth the effort.
@n61ab the screenshot you've shared shows that msg.payloads is a Buffer type. That is why the toString() function Colin suggests works.
Here's a quick function that will do the string conversion and then split out the number:
// Convert Buffer to String:
var data = msg.payload.toString()
// Split it using the `:` character
var parts = data.split(":");
// parts is now a two-element array, containing "AZ" and "129.9"
// use the second element:
msg.payload = parts[1];
return msg
Colin and knolleary
Thanks for your help. I will give this a try this afternoon and let you know how I do.
Alan
knolleary
I could not wait! Your function works great! How can I say thank-you enough?
Alan
Doh, I must remember to engage brain before typing.
