Parsing HTML filter out two values
Hi! I would like to filter out two values from a homepage: the article number: and the price.
I've been trying for a few hours now but it doesn't work.
Maybe someone can help me there.
I have circled the two values in the picture.
I tried this for you:
        "id": "9eee6b55a7fac9c9",
        "type": "http request",
        "z": "ebe8134f6b5af26c",
        "method": "GET",
        "ret": "txt",
        "paytoqs": "ignore",
        "url": "https://www.ruddog.eu/Hiro-Seiko-MTC1-Titan-Alum-Hex-Socket-Screw-Set-S-Black",
        "tls": "",
        "persist": false,
        "proxy": "",
        "authType": "",
        "senderr": false,
        "x": 550,
        "y": 480,
                "bc3f4457783188a5",
                "13fea09c0c74a327"
        "id": "719173114ca09950",
        "type": "inject",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "true",
        "payloadType": "bool",
        "x": 390,
        "y": 480,
                "9eee6b55a7fac9c9"
        "id": "bc3f4457783188a5",
        "type": "html",
        "property": "payload",
        "outproperty": "payload",
        "tag": "p[class=\"text-muted product-sku\"]",
        "ret": "text",
        "as": "single",
        "x": 800,
        "y": 480,
                "96af5751210385d5"
        "id": "13fea09c0c74a327",
        "type": "html",
        "tag": "span[class=\"price text-nowrap\"]",
        "ret": "text",
        "as": "single",
        "x": 790,
        "y": 520,
                "8031ed2a8ea40d02"
        "id": "8f44b9ee281e742b",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "",
        "statusType": "auto",
        "x": 1430,
        "y": 500,
        "id": "96af5751210385d5",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "Artikel",
                "tot": "str"
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "payload[0]",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1070,
        "y": 480,
                "87eb375f7b15276f"
        "id": "8031ed2a8ea40d02",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "Preis",
                "tot": "str"
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "payload[0]",
                "tot": "msg"
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "$trim(payload)\t",
                "tot": "jsonata"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1070,
        "y": 520,
                "87eb375f7b15276f"
        "id": "87eb375f7b15276f",
        "type": "join",
        "mode": "custom",
        "build": "object",
        "propertyType": "msg",
        "key": "topic",
        "joiner": "\\n",
        "joinerType": "str",
        "accumulate": false,
        "timeout": "",
        "count": "2",
        "reduceRight": false,
        "reduceExp": "",
        "reduceInit": "",
        "reduceInitType": "",
        "reduceFixup": "",
        "x": 1270,
        "y": 500,
                "8f44b9ee281e742b"
The values can further be further extracted.
Hi! Thanks a lot, that will definitely help me.
Hi! I remembered something else. Is it possible to log in to the homepage and then read out the data?
Once you go a bit past the basic HTTP Request needs (for example: logging in and navigating between a set of web pages) you might need to start using WebDriver IO (WDIO): npm install node-red-contrib-wdio
This (in conjunction with a shell session running 'selenium-standalone start' can let you automate even very complex web page interactions including 'scraping' web sites or pushing data to them.
Cheers,
Paul
