I'm trying to parse a JSON value, the value is as follows :
{"ZbReceived":{"0xF063":{"Device":"0xF063","Name":"Sonoff_Motion_sensor","0500<00":"000000000000","ZoneStatusChange":0,"Occupancy":0,"Endpoint":1,"LinkQuality":45}}}
I'm interested in the value of Occupancy, and normally converting the result to JSON and then accessing the value as follows would work :
var newMsg = { payload: msg.payload.ZbReceived.0xF062.Occupancy };
return newMsg;
However, the above code gives an error of "Unexpected '.'."
What is the proper escape character in order to convince Node Red to behave as expected?
Thanks in advance.
I think you may need to put the message through the JSON node and then it may be more usable.
Oh, edit your post and use the </> button to post the message.
Makes it easier for others.
If you used the Microsoft alternate code editor instead of ACE, you would have seen the error
You can't have a plain property name that starts with a number. So to access that data, you need:
return {
payload: msg.payload.ZbReceived["0xF063"].Occupancy
Thanks @TotallyInformation, that worked great ^^
The node red code ended up being :
if (msg.payload.ZbReceived['0xF062'].Device == '0xF062'){
var newMsg = { payload: msg.payload.ZbReceived['0xF062'].Occupancy };
return newMsg;
} else {
return null;
