Payload address has a decimal (period)
I am receiving these data from a sensor:
"pm25": 27,
"pm10": 30,
"pm1.0": 20,
"temperature": 17.5,
"humidity": 35.5
I have success in getting the data using below code, as an example:
var newMsg = { payload: msg.payload.pm10 };
My problem comes from the data for pm1.0, I cannot type
var newMsg = { payload: msg.payload.pm1.0 };
As the "." will be like a separator. Tried doing this but still does not work:
var newMsg = { payload: msg.payload."pm1.0" };
A bit new to Node-red, not really sure how to resolve this. Big thanks to anyone who will help!
There’s a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path to any data item.
BX00Cy7yHi
Hi Steve,
Thanks a lot, very helpful for me.
By the way, just found the solution to my problem, I just needed to change the code to this:
var newMsg = { payload: msg.payload["pm1.0"] };
Thanks!
Which is what the methods in the linked page would have allowed you to determine.
