Retrieve values from payload object
Hi all,
New to node-red here, and looking to store some IoT data coming from TTN into a postgres database.
I am having a hard time formatting the data.
Here is the payload I receive
4/21/2023, 1:19:29 AM[node: msg.payload](http://xx.xxx.xx.xxx:1880/#)v3/xxxxx@sxxxx/devices/eui-x/up : msg.payload : Object
object
Bat: 3.354
TempC_DS18B20: "0.0"
conduct_SOIL: 89
temp_SOIL: "21.04"
water_SOIL: "22.02"`
Here is the function I use to format the data :
msg.payload = {
        timestamp_data: new Date(),
        device_battery: parseFloat(msg.payload.Bat),
        soil_conductivity: parseInt(msg.payload.conduct_SOIL),
        soil_temperature: parseFloat(msg.payload.temp_SOIL),
        soil_humidity: parseFloat(msg.payload.water_SOIL)
But when I do this here is what I receive :
4/21/2023, 1:33:24 AM[node: msg.payload](http://xx.xxx.xx.xxx:1880/#)v3/xxxxx@sowit/devices/eui-x/up : msg.payload : Object
{ timestamp_data: "2023-04-21T01:33:23.953Z", device_battery: NaN, soil_conductivity: NaN, soil_temperature: NaN, soil_humidity: NaN }
I don't understand why I get NaN instead of the values, happy to get your insights.
Thanks,
HB
Can you put a debug node on and let us see the output of the data that you are getting returned back from the API call ?
That would make it easier to understand what us happening
Craig
MODERATOR NOTE: I have edited your post and removed the IP address you included as your NR site is accessible from the internet.
THIS IS DANGEROUS AND YOU OPEN YOURSELF TO BEING HACKED.
I would recommend you take steps to secure your site before you do anything else!
Hi @zenofmud thank you for the initiative, point taken.
best regards,
HB
Add a debug node to the output of all the mqtt-in nodes to show the data each function node is getting. Then copy/paste the debug's msg.payload in a response.
Is that the debug output of the mqtt-in node that feeds the function node with the issue?
You are trying to access msg.payload.Bat but the value for "Bat" is msg.payload.uplink_message.decoded_payload.Bat.
I discovered this using the "Copy path" button on the debug panel.
Thanks @jbudd solved the issue
