Pass through Objects?
Hi All, Please disregard this question, I think I figured out the solution. It's much easier than I was thinking to allow the creation of a new msg object and have it saved properly on the pass through of another node.
Hi All,
New to Node Red here have a question on how we handle pass through values. The specific example I'm trying to solve is to create a OPC monitor which pulls selected nodes from a SQL Server then passes those nodes to OPCUA which retrieves the value then stores back into SQL Server. I have the base working fine however, I'm struggling in how to handle the id of my nodes. In the below example I pull a list of ID's and Nodes from a given table. I then loop through this list and pass the Node id to the OPCUA client. How can I pass the ID to the OPCUA client without it trying to use it as a node? Instead I only want to match the id with the value returned from the OPCUA client.
Thanks!
Craig
[{"id":"4011d7fc.c791d8","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"d81df181.aec6b","type":"inject","z":"4011d7fc.c791d8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":"15","topic":"ns=4;s=Demo.BoilerDemo.Boiler1.FillLevelSensor.FillLevel;datatype=Double","payload":"","payloadType":"date","x":120,"y":580,"wires":[["9c040248.fd76e"]]},{"id":"95fce55d.7fb628","type":"inject","z":"4011d7fc.c791d8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":"30","topic":"ns=4;s=Demo.BoilerDemo.Boiler1.TemperatureSensor.Temperature;datatype=Double","payload":"","payloadType":"date","x":120,"y":740,"wires":[["9c040248.fd76e"]]},{"id":"2ed79708.c13f68","type":"template","z":"4011d7fc.c791d8","name":"SQL Script","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"INSERT INTO OPC_Test(Node, Value) VALUES ('Test',{{payload}});","output":"str","x":770,"y":600,"wires":[["50a0c33e.c2116c","1a5124e8.0d35eb"]]},{"id":"50a0c33e.c2116c","type":"MSSQL","z":"4011d7fc.c791d8","mssqlCN":"e7d03fe4.833fd","name":"MSSQL","query":"","outField":"payload","x":1100,"y":600,"wires":[[]]},{"id":"381a7f3e.2cb6e","type":"inject","z":"4011d7fc.c791d8","name":"Get Automation Channel","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":"5","topic":"","payload":"SELECT ADDRESS FROM [Automation_Channel] WHERE AUTO_CHANNEL_ID = 1","payloadType":"str","x":150,"y":140,"wires":[["2740156.d82a1ea"]]},{"id":"1a5124e8.0d35eb","type":"debug","z":"4011d7fc.c791d8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1090,"y":680,"wires":[]},{"id":"9c040248.fd76e","type":"OpcUa-Client","z":"4011d7fc.c791d8","endpoint":"21ab681f.beedd8","action":"read","deadbandtype":"a","deadbandvalue":1,"time":10,"timeUnit":"s","certificate":"n","localfile":"","localkeyfile":"","securitymode":"None","securitypolicy":"None","name":"","x":480,"y":660,"wires":[["2ed79708.c13f68","7c99da2e.b19844"]]},{"id":"3cb401cd.9b27ee","type":"inject","z":"4011d7fc.c791d8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":"20","topic":"ns=4;s=Demo.BoilerDemo.Boiler1.TemperatureSetPoint;datatype=Double","payload":"","payloadType":"date","x":120,"y":660,"wires":[["9c040248.fd76e"]]},{"id":"7c99da2e.b19844","type":"ui_gauge","z":"4011d7fc.c791d8","name":"","group":"d44d4f44.3219e8","order":2,"width":0,"height":0,"gtype":"gage","title":"gauge","label":"units","format":"{{value}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":750,"y":680,"wires":[]},{"id":"2740156.d82a1ea","type":"MSSQL","z":"4011d7fc.c791d8","mssqlCN":"e7d03fe4.833fd","name":"MSSQL","query":"","outField":"payload","x":380,"y":140,"wires":[["e3ae48f4.f33928"]]},{"id":"e9a73b84.b437f8","type":"debug","z":"4011d7fc.c791d8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":750,"y":140,"wires":[]},{"id":"e3ae48f4.f33928","type":"function","z":"4011d7fc.c791d8","name":"","func":"for (var i = 0; i < msg.payload.length; i++) {\n var newMsg = {};\n newMsg.payload = msg.payload[i].ADDRESS;\n node.send(newMsg);\n}\nreturn null;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":560,"y":140,"wires":[["e9a73b84.b437f8"]]},{"id":"f237291f.39a1c8","type":"inject","z":"4011d7fc.c791d8","name":"Get Automation Channel","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"600","crontab":"","once":false,"onceDelay":"10","topic":"","payload":"SELECT AUTO_NODE_INST_PARAM_ID, ADDRESS FROM [Automation_Node_Instance_Param] WHERE AUTO_CHANNEL_ID = 1","payloadType":"str","x":150,"y":260,"wires":[["59064002.2d732"]]},{"id":"59064002.2d732","type":"MSSQL","z":"4011d7fc.c791d8","mssqlCN":"e7d03fe4.833fd","name":"MSSQL","query":"","outField":"payload","x":380,"y":260,"wires":[["6396af62.6276c"]]},{"id":"6396af62.6276c","type":"function","z":"4011d7fc.c791d8","name":"Loop Function","func":"for (var i = 0; i < msg.payload.length; i++) {\n var newMsg = {};\n newMsg.id = msg.payload[i].AUTO_NODE_INST_PARAM_ID;\n newMsg.topic = msg.payload[i].ADDRESS;\n node.send(newMsg);\n}\nreturn null;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":580,"y":260,"wires":[["ee26c60f.9914b8"]]},{"id":"ee26c60f.9914b8","type":"OpcUa-Client","z":"4011d7fc.c791d8","endpoint":"21ab681f.beedd8","action":"read","deadbandtype":"a","deadbandvalue":1,"time":10,"timeUnit":"s","certificate":"n","localfile":"","localkeyfile":"","securitymode":"None","securitypolicy":"None","name":"","x":800,"y":260,"wires":[["ea1de054.fdf46","11b9d45f.cc126c"]]},{"id":"ea1de054.fdf46","type":"template","z":"4011d7fc.c791d8","name":"SQL Script","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"INSERT INTO OPC_Test(Node, Value) VALUES ('Test',{{payload}});","output":"str","x":1010,"y":260,"wires":[["c00f4241.a868"]]},{"id":"ab6918de.cc4298","type":"MSSQL","z":"4011d7fc.c791d8","mssqlCN":"e7d03fe4.833fd","name":"MSSQL","query":"","outField":"payload","x":580,"y":360,"wires":[[]]},{"id":"fa022176.f3f0b","type":"debug","z":"4011d7fc.c791d8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":390,"y":440,"wires":[]},{"id":"8c106f4.164bd9","type":"delay","z":"4011d7fc.c791d8","name":"SQL Delay","pauseType":"queue","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":true,"x":390,"y":360,"wires":[["ab6918de.cc4298"]]},{"id":"c00f4241.a868","type":"join","z":"4011d7fc.c791d8","name":"Join SQL Statements","mode":"custom","build":"string","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"10","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"num","reduceFixup":"","x":160,"y":360,"wires":[["fa022176.f3f0b","8c106f4.164bd9"]]},{"id":"968912e2.ac10c","type":"OpcUa-Browser","z":"4011d7fc.c791d8","endpoint":"21ab681f.beedd8","item":"","datatype":"","topic":"","items":[],"name":"","x":130,"y":40,"wires":[["807d7dec.4b8d"]]},{"id":"807d7dec.4b8d","type":"ui_template","z":"4011d7fc.c791d8","group":"d44d4f44.3219e8","name":"","order":3,"width":"6","height":"10","format":"<div layout=\"row\" layout-align=\"space-between\">\n    <select ng-model=\"item\" ng-options=\"items.item.displayName.txt for items in msg.payload\">\n        <option value=\"\">-- Objects Root --</option>\n    </select>\n</div>\nPress to update:\n<div layout=\"row\" layout-align=\"space-between\">\n    <button ng-clivk=\"send({payload: {actiontype: 'browse', root: item}})\">\n        Browse\n    </button>\n</div>\n<div layout=\"row\" layout-align=\"space-between\">\n    <ul>\n        <li ng-repeat=\"items in msg.payload\">\n            {{items.item.displayName.text}}: {{items.item.nodeId}}\n        </li>\n    </ul>\n</div>","storeOutMessages":false,"fwdInMessages":false,"resendOnRefresh":true,"templateScope":"local","x":340,"y":40,"wires":[["968912e2.ac10c"]]},{"id":"11b9d45f.cc126c","type":"debug","z":"4011d7fc.c791d8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1010,"y":400,"wires":[]},{"id":"e7d03fe4.833fd","type":"MSSQL-CN","name":"SQL_Express","server":"CRAIG-DESKTOP\\SQLEXPRESS","encyption":false,"database":"OCD"},{"id":"21ab681f.beedd8","type":"OpcUa-Endpoint","endpoint":"opc.tcp://CRAIG-DESKTOP:48020","secpol":"None","secmode":"None","login":false},{"id":"d44d4f44.3219e8","type":"ui_group","name":"Sensors","tab":"34054411.bf9404","order":1,"disp":true,"width":"12","collapse":false},{"id":"34054411.bf9404","type":"ui_tab","name":"Home","icon":"dashboard"}]
Welcome to the forum @Mav
I am not entirely sure this answers the question, but if you want to pass a value down the wires in such a way that it does not interfere with the operation of other nodes then you can use a unique property name. So, for example, you might set msg.theID to the ID you want, then further on you can access that that and intervening nodes should not have touched it. By using a unique property it does not affect msg.payload or msg.topic or other properties.
