Passing HTML and CSS between template node and UI template node
Hello all, I am new to HTML and CSS and I have been reading through the forum for a while looking for a solution to this problem.
I currently have 4 template nodes, all of which contain HTML and CSS styling. I am using a switch node to select which template I want to use, and then passing it to a UI template node to make the dashboard match based on certain criteria.
The issue I am having is that I can get the CSS to pass using {{msg.format}} between style elements, but I cannot get the HTML to pass as well. I know that when sending msg.payload to the UI template node it reads it as plain text, and when I send msg.payload to the UI template with the ng-bind-html it does not seem to work with the CSS.
The HTML and CSS contained in the template nodes works when placed in the UI template node, but it is not being displayed correctly when I am attempting to pass it. I am doing something wrong when attempting to send both, but I cannot figure out my issue.
I have attached some of the nodes below. Thank you all for the help.
        "id": "ee4bd0e8e4ddfc95",
        "type": "switch",
        "z": "1982ff5883559295",
        "name": "Years?",
        "property": "payload.Years",
        "propertyType": "msg",
        "rules": [
                "t": "eq",
                "v": "5",
                "vt": "str"
                "t": "eq",
                "v": "10",
                "vt": "str"
                "t": "eq",
                "v": "15",
                "vt": "str"
                "t": "eq",
                "v": "20",
                "vt": "str"
                "t": "eq",
                "v": "25",
                "vt": "str"
                "t": "else"
        "checkall": "true",
        "repair": false,
        "outputs": 6,
        "x": 790,
        "y": 920,
                "2897efa418c1ed99"
                "2897efa418c1ed99"
                "2897efa418c1ed99"
                "2897efa418c1ed99"
                "2897efa418c1ed99"
                "994479d4c5b5c50a"
        "id": "2897efa418c1ed99",
        "type": "switch",
        "name": "Photo?",
        "property": "payload.Photo",
        "rules": [
                "t": "null"
                "t": "else"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 960,
        "y": 900,
                "ca482628d86ab917"
                "fd15eecd964bc93e"
        "id": "994479d4c5b5c50a",
        "type": "switch",
        "name": "Photo?",
        "rules": [
                "t": "null"
                "t": "else"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 960,
        "y": 940,
                "cdeca4b4430a7939"
                "c516bdf2c0ec7afb"
        "id": "ca482628d86ab917",
        "type": "template",
        "name": "milestone, no photo",
        "field": "payload",
        "fieldType": "msg",
        "format": "handlebars",
        "syntax": "mustache",
        "template": "<head  style=\"background: transparent !important;border: transparent;\">\n    <meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">\n   \n    <style>\n       body {\n            background-image: url(\"/Celebration/Milestone Year Background.jpg\");\n            background-repeat: no-repeat;\n            background-position: center;\n            background-size: cover; //100%;\n        }\n\n        body.nr-dashboard-theme md-content md-card {\n            border-radius: 20px;\n            background: transparent !important;\n            border: transparent;\n        }\n\n        #nr-dashboard > md-content > section > md-content {\n            overflow: hidden; /*removes scrollbar*/\n        }\n        \n         #Tab_html_testing2 {\n            justify-content: center;\n        }\n        \n        #html_testing2_Group_1_cards {\n            width: 100vw !important;\n            height: 100vh !important;\n            margin-left: 13.5vw;\n        }\n        \n        #html_testing2_Group_1_cards > md-card {\n            width: 100vw !important;\n            position: relative;\n        }\n        \n        .nr-dashboard-cardpanel {\n            width: 100vw !important;\n        }\n        \n        .nr-dashboard-theme ui-card-panel {\n            border-radius: 20px;\n            background: transparent !important;\n            border: transparent;\n            justify-content: center;\n        }\n            \n        .container {\n            /*float: right;*/\n            position: relative;\n            text-align: center;\n            background: transparent !important;\n            border: transparent;\n        }\n\n        .centered {\n            position: absolute;\n            left: 50%;\n            transform: translate(-50%, -50%);\n            background: transparent !important;\n            border: transparent;\n        }\n\n        .row {\n            background: transparent !important;\n            border: transparent;\n            display: flex;\n            flex-wrap: nowrap;\n            width: 75vw !important;\n            height: 80vh !important;\n            margin-top: 10vh;\n            justify-content: center;\n            align-items: center;\n            flex-direction: column;\n        }\n\n        .column {\n            background: #F0BF60 !important;\n            flex: 45% !important;\n            border-radius: 10px;\n            text-align: center;\n            border: 2px solid white;\n            flex-direction: column;\n            height: auto;\n        }\n        \n    </style>\n</head>\n\n\n\n<div class=\"row\">\n    <div class=\"column\">\n        <h2 style=\"background:transparent !important; font-size:2.75vw;\">Thank you for your time here at eCMMS!</h2>\n        <div class=\"container\" style=\"width:100%; background:transparent !important; background-position:center; flex: 2 1 auto;\">\n            <img src=\"/Celebration/Milestone Year.jpg\" alt=\"Image not working right\" style=\"width:100%; background:transparent !important; flex: 3 1 auto;\">\n            <div class=\"centered\" style=\"color:black; font-size:10vw; top:45%; background:transparent !important; flex: 2 1 auto;\">{{msg.payload.Years}}</div>\n        </div>\n                <h2 style=\"background:transparent !important; font-size:4vw !important;\">{{msg.payload.Name}}</h2>\n                <h2 style=\"background:transparent !important; font-size:2vw !important;\">{{msg.payload.JobTitleDescription}} - {{msg.payload.HireDate}}</h2>\n    </div>\n</div>",
        "output": "str",
        "x": 1150,
        "y": 860,
                "b8de27470dd67b1d"
        "id": "fd15eecd964bc93e",
        "type": "template",
        "name": "milestone, photo",
        "field": "payload",
        "fieldType": "msg",
        "template": "<head  style=\"background: transparent !important;border: transparent;\">\n    <meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">\n    \n <style>\n        body {\n            background-image: url(\"/Celebration/Milestone Year Background.jpg\");\n            background-repeat: no-repeat;\n            background-position: center;\n            background-size: cover; //100%;\n        }\n\n        body.nr-dashboard-theme md-content md-card {\n            border-radius: 20px;\n            background: transparent !important;\n            border: transparent !important;\n        }\n     \n        #html_testing2_Group_1 {\n            width: 75vw;\n            height: 76vh;\n            background: transparent;\n            border: transparent;\n            margin-top: 10vh;\n        }\n        \n        #html_testing2_Group_1_cards > md-card {\n            width: 75vw !important;\n            height: 100vh !important;\n            overflow-x: hidden !important;\n        }\n        \n        .row {\n            display: flex;\n            height: 75vh;\n            border: 3px solid white;\n            border-radius: 5px;\n        }\n\n        .column {\n            flex: 1;\n            width: 50vw;\n            border: transparent;\n            background-color: #F0BF60;\n        }\n        \n        .column:nth-child(1) { \n            /*margin-right: 10px;*/\n        }\n        \n        .column:nth-child(2) {\n            \n        }\n        \n        .container  {\n            background: transparent !important;\n            border: transparent !important;\n            width: 100%;\n            height: 100%;\n            overflow: visible;\n        }\n        \n        .centered {\n            /*position: absolute;*/\n            background: transparent !important;\n            border: transparent;\n        }\n        \n        .centered:nth-child(2) {\n            font-size: 10vw;\n            text-align: center;\n            white-space: nowrap;\n            transform: translate(0%, -270%) !important;\n            /*top: 80%;*/\n        }\n        \n        .centered:nth-child(3) {\n            font-size: 3.5vw;\n            text-align: center;\n            white-space: nowrap;\n            transform: translate(0%, -410%) !important;\n            /*top: 45%;*/\n        }\n        \n        .img {\n            background:transparent !important;\n            display: block;\n            margin-left: auto;\n            margin-right: auto;\n            width: 75%;\n            border: 2px white solid;\n        }\n        \n    </style>\n</head>\n\n\n\n<div class=\"row\">\n    <div class=\"column one\">\n        <h2 style=\"background:transparent !important; font-size:2vw; text-align:center;\">Thank you for your time here at eCMMS!</h2>\n        <img src=\"{{msg.payload.Photo}}\" class=\"img one\">\n        <h2 style=\"background:transparent !important; font-size:3vw; text-align:center;\">{{msg.payload.Name}}</h2>\n        <h2 style=\"background:transparent !important; font-size:1.75vw; text-align:center;\">{{msg.payload.JobTitleDescription}}</h2>\n    </div>\n    \n    <div class=\"column two\">\n       <div class=\"container\">\n            <img src=\"/Celebration/Blank Year Icon.jpg\" style=\"width:100%; height:100%; background:transparent !important\">\n            <div class=\"centered one\">{{msg.payload.Years}}</div>\n            <div class=\"centered two\">{{msg.payload.HireDate}}</div>\n        </div>\n    </div>\n</div>",
        "output": "str",
        "x": 1160,
        "y": 900,
                "b8de27470dd67b1d"
        "id": "c516bdf2c0ec7afb",
        "type": "template",
        "name": "general, photo",
        "field": "payload",
        "fieldType": "msg",
        "template": "<head  style=\"background: transparent !important;border: transparent;\">\n    <meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">\n    \n <style>\n        body {\n            background-image: url(\"/Celebration/General Year Background.jpg\");\n            background-repeat: no-repeat;\n            background-position: center;\n            background-size: cover; //100%;\n        }\n\n        body.nr-dashboard-theme md-content md-card {\n            border-radius: 20px;\n            background: transparent !important;\n            border: transparent !important;\n        }\n     \n        #html_testing2_Group_1 {\n            width: 75vw;\n            height: 76vh;\n            background: transparent;\n            border: transparent;\n            margin-top: 10vh;\n        }\n        \n        #html_testing2_Group_1_cards > md-card {\n            width: 75vw !important;\n            height: 100vh !important;\n            overflow-x: hidden !important;\n        }\n        \n        .row {\n            display: flex;\n            height: 75vh;\n            border: 3px solid white;\n            border-radius: 5px;\n        }\n\n        .column {\n            flex: 1;\n            width: 50vw;\n            border: transparent;\n            background-color: #2F5597;\n        }\n        \n        .column:nth-child(1) { \n            /*margin-right: 10px;*/\n        }\n        \n        .column:nth-child(2) {\n            \n        }\n        \n        .container  {\n            background: transparent !important;\n            border: transparent !important;\n            width: 100%;\n            height: 100%;\n            overflow: visible;\n        }\n        \n        .centered {\n            /*position: absolute;*/\n            background: transparent !important;\n            border: transparent;\n        }\n        \n        .centered:nth-child(2) {\n            font-size: 10vw;\n            text-align: center;\n            white-space: nowrap;\n            transform: translate(0%, -270%) !important;\n            /*top: 80%;*/\n        }\n        \n        .centered:nth-child(3) {\n            font-size: 3.5vw;\n            text-align: center;\n            white-space: nowrap;\n            transform: translate(0%, -410%) !important;\n            /*top: 45%;*/\n        }\n        \n        .img {\n            background:transparent !important;\n            display: block;\n            margin-left: auto;\n            margin-right: auto;\n            width: 75%;\n            border: 2px white solid;\n        }\n        \n    </style>\n</head>\n\n\n\n<div class=\"row\">\n    <div class=\"column one\">\n        <h2 style=\"color:white !important; background:transparent !important; font-size:2vw; text-align:center;\">Thank you for your time here at eCMMS!</h2>\n        <img src=\"{{msg.payload.Photo}}\" class=\"img one\">\n        <h2 style=\"color:white !important; background:transparent !important; font-size:3vw; text-align:center;\">{{msg.payload.Name}}</h2>\n        <h2 style=\"color:white !important; background:transparent !important; font-size:1.75vw; text-align:center;\">{{msg.payload.JobTitleDescription}}</h2>\n    </div>\n    \n    <div class=\"column two\">\n       <div class=\"container\">\n            <img src=\"/Celebration/Blank Year Icon.jpg\" style=\"width:100%; height:100%; background:transparent !important\">\n            <div class=\"centered one\">{{msg.payload.Years}}</div>\n            <div class=\"centered two\">{{msg.payload.HireDate}}</div>\n        </div>\n    </div>\n</div>",
        "output": "str",
        "x": 1160,
        "y": 980,
                "b8de27470dd67b1d"
        "id": "cdeca4b4430a7939",
        "type": "template",
        "name": "general, no photo",
        "field": "payload",
        "fieldType": "msg",
        "template": "<head  style=\"background: transparent !important;border: transparent;\">\n    <meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">\n   \n    <style>\n       #nr-dashboard-toolbar {\n           background: transparent !important;\n           color: blue;\n       }\n       \n       body {\n            background-image: url(\"/Celebration/General Year Background.jpg\");\n            background-repeat: no-repeat;\n            background-position: center;\n            background-size: cover; //100%;\n        }\n        \n        body.nr-dashboard-theme md-content md-card {\n            border-radius: 20px;\n            background: transparent !important;\n            border: transparent;\n        }\n        \n        #Tab_html_testing2 {\n            justify-content: center;\n        }\n        \n        #nr-dashboard > md-content > section > md-content {\n            overflow: hidden; /*removes scrollbar*/\n        }\n\n        #html_testing2_Group_1_cards {\n            width: 100vw !important;\n            height: 100vh !important;\n            margin-left: 13.5vw;\n        }\n        \n        #html_testing2_Group_1_cards > md-card {\n            width: 100vw !important;\n        }\n        \n        .nr-dashboard-cardpanel {\n            width: 100vw !important;\n        }\n        \n        .nr-dashboard-theme ui-card-panel {\n            border-radius: 20px;\n            background: transparent !important;\n            border: transparent;\n            justify-content: center;\n        }\n            \n        .container {\n            /*float: right;*/\n            position: relative;\n            text-align: center;\n            background: transparent !important;\n            border: transparent;\n        }\n\n        .centered {\n            position: absolute;\n            left: 50%;\n            transform: translate(-50%, -50%);\n            background: transparent !important;\n            border: transparent;\n        }\n\n        .row {\n            background: transparent !important;\n            border: transparent;\n            display: flex;\n            flex-wrap: nowrap;\n            width: 75vw !important;\n            height: 80vh !important;\n            margin-top: 10vh;\n            justify-content: center;\n            align-items: center;\n            flex-direction: column;\n        }\n\n        .column {\n            background: #2F5597 !important;\n            flex: 45% !important;\n            border-radius: 10px;\n            text-align: center;\n            border: 2px solid white;\n            flex-direction: column;\n        }\n        \n    </style>\n</head>\n\n\n\n<div class=\"row\">\n    <div class=\"column\">\n        <h2 style=\"background:transparent !important; color:white !important; font-size:2.75vw;\">Thank you for your time here at eCMMS!</h2>\n        <div class=\"container\" style=\"width:100%; background:transparent !important; background-position:center; flex: 2 1 auto;\">\n            <img src=\"/Celebration/General Year.png\" alt=\"Image not working right\" style=\"width:100%; background:transparent !important; flex: 3 1 auto;\">\n            <div class=\"centered\" style=\"color:black; font-size:10vw; top:40%; background:transparent !important; flex: 2 1 auto;\">{{msg.payload.Years}}</div>\n        </div>\n                <h2 style=\"background:transparent !important; color:white !important; font-size:4vw !important;\">{{msg.payload.Name}}</h2>\n                <h2 style=\"background:transparent !important; color:white !important; font-size:2vw !important;\">{{msg.payload.JobTitleDescription}} - {{msg.payload.HireDate}}</h2>\n    </div>\n</div>",
        "output": "str",
        "x": 1150,
        "y": 940,
                "b8de27470dd67b1d"
        "id": "b8de27470dd67b1d",
        "type": "ui_template",
        "group": "03037d81efd28297",
        "name": "Selection Template",
        "order": 6,
        "width": 0,
        "height": 0,
        "format": "<div ng-bind-html=\"msg.payload\"></div>",
        "storeOutMessages": true,
        "fwdInMessages": true,
        "resendOnRefresh": true,
        "templateScope": "local",
        "className": "",
        "x": 1390,
        "y": 920,
        "id": "03037d81efd28297",
        "type": "ui_group",
        "name": "Group 1",
        "tab": "39a195775f2e9c27",
        "order": 1,
        "disp": false,
        "width": "15",
        "collapse": false,
        "className": ""
        "id": "39a195775f2e9c27",
        "type": "ui_tab",
        "name": "html testing2",
        "icon": "dashboard",
        "order": 1,
        "disabled": false,
        "hidden": false
Hi.
The template node does not use msg at start, so it would be {{payload.whatever}}.
Then you would output msg.template and in the ui-template node you leave the template field blank.
Finally The ui-dashboard already has a <head> section so you should not add it again.
Example
[{"id":"40e35b665732e43f","type":"inject","z":"b9860b4b9de8c8da","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"Years\":\"5\",\"Name\":\"tom\",\"JobTitleDescription\":\"gaffer\",\"HireDate\":\"1-1-0\"}","payloadType":"json","x":610,"y":3500,"wires":[["fd15eecd964bc93e"]]},{"id":"fd15eecd964bc93e","type":"template","z":"b9860b4b9de8c8da","name":"milestone, photo","field":"template","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"    <meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">\n    \n <style>\n        body {\n            background-image: url(\"/Celebration/Milestone Year Background.jpg\");\n            background-repeat: no-repeat;\n            background-position: center;\n            background-size: cover; //100%;\n        }\n\n        body.nr-dashboard-theme md-content md-card {\n            border-radius: 20px;\n            background: transparent !important;\n            border: transparent !important;\n        }\n     \n        #html_testing2_Group_1 {\n            width: 75vw;\n            height: 76vh;\n            background: transparent;\n            border: transparent;\n            margin-top: 10vh;\n        }\n        \n        #html_testing2_Group_1_cards > md-card {\n            width: 75vw !important;\n            height: 100vh !important;\n            overflow-x: hidden !important;\n        }\n        \n        .row {\n            display: flex;\n            height: 75vh;\n            border: 3px solid white;\n            border-radius: 5px;\n        }\n\n        .column {\n            flex: 1;\n            width: 50vw;\n            border: transparent;\n            background-color: #F0BF60;\n        }\n        \n        .column:nth-child(1) { \n            /*margin-right: 10px;*/\n        }\n        \n        .column:nth-child(2) {\n            \n        }\n        \n        .container  {\n            background: transparent !important;\n            border: transparent !important;\n            width: 100%;\n            height: 100%;\n            overflow: visible;\n        }\n        \n        .centered {\n            /*position: absolute;*/\n            background: transparent !important;\n            border: transparent;\n        }\n        \n        .centered:nth-child(2) {\n            font-size: 10vw;\n            text-align: center;\n            white-space: nowrap;\n            transform: translate(0%, -270%) !important;\n            /*top: 80%;*/\n        }\n        \n        .centered:nth-child(3) {\n            font-size: 3.5vw;\n            text-align: center;\n            white-space: nowrap;\n            transform: translate(0%, -410%) !important;\n            /*top: 45%;*/\n        }\n        \n        .img {\n            background:transparent !important;\n            display: block;\n            margin-left: auto;\n            margin-right: auto;\n            width: 75%;\n            border: 2px white solid;\n        }\n        \n    </style>\n\n\n\n\n<div class=\"row\">\n    <div class=\"column one\">\n        <h2 style=\"background:transparent !important; font-size:2vw; text-align:center;\">Thank you for your time here at eCMMS!</h2>\n        <img src=\"{{payload.Photo}}\" class=\"img one\">\n        <h2 style=\"background:transparent !important; font-size:3vw; text-align:center;\">{{payload.Name}}</h2>\n        <h2 style=\"background:transparent !important; font-size:1.75vw; text-align:center;\">{{payload.JobTitleDescription}}</h2>\n    </div>\n    \n    <div class=\"column two\">\n       <div class=\"container\">\n            <img src=\"/Celebration/Blank Year Icon.jpg\" style=\"width:100%; height:100%; background:transparent !important\">\n            <div class=\"centered one\">{{payload.Years}}</div>\n            <div class=\"centered two\">{{payload.HireDate}}</div>\n        </div>\n    </div>\n</div>","output":"str","x":820,"y":3500,"wires":[["b8de27470dd67b1d"]]},{"id":"b8de27470dd67b1d","type":"ui_template","z":"b9860b4b9de8c8da","group":"03037d81efd28297","name":"Selection Template","order":6,"width":0,"height":0,"format":"","storeOutMessages":false,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","className":"","x":1050,"y":3520,"wires":[[]]},{"id":"03037d81efd28297","type":"ui_group","name":"Group 1","tab":"39a195775f2e9c27","order":1,"disp":false,"width":"15","collapse":false,"className":""},{"id":"39a195775f2e9c27","type":"ui_tab","name":"html testing2","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
Thank you for the help. When I run the nodes that you provided, they just display the desired background, but nothing else seems to be present. Using inspect element on the dashboard shows that all my HTML classes are the right size and in the right place, but it does not display anything other than the background.
What you provided also works while run in the UI template, but not when passed to it from the template node itself.
When I run the example I supplied unedited, I get.
[edit] Are you outputting msg.template from the template node?
That is what it should look like, so that is why I am confused. And yes, I am outputting msg.template. Everything you had in the inject node is showing up in the html using inspect element (tom, gaffer, 5, 1-1-0), it just isn't displaying anything other than the background.
Could it possibly be that I am running Node-RED v2.2.0? I am testing all this on our dev server and maybe the older version has something different? I will try and run it on our updated version tomorrow probably and see how that works.
Try clearing your browser cache and refreshing the page, as you have been messing/adding things/deleting things/ etc, your bowser is most probably a little confused
I just ran it on Node-Red v3.0.2 and it worked correctly. Clearing the browser cache helped as well. Thank you very much for your help. Sorry it was such an easy fix that I overlooked.
