Hi Team, Currently I am using Node-Red 3.1.8. I followed document how to apply password protection but still not working.
adminAuth: {
type: "credentials",
users: [{
username: "admin",
password: "$2b$08$260oPVF33WAQsV60LUlQXu6g22Ub9R35ycBdSFghPNx//hrqVgbxS",
permissions: "*"
httpNodeAuth: {user:"user",pass:"$2a$08$zZWtXTja0fB1pzD4sHCMyOCMYz2Z6dNbM6tl8sJogENOMcxWV9DN."},
Kindly guide me
Hi @k-usama1495
Have you restarted Node RED after applying the changes to settings.js?
yes,
"start": "node packages/node_modules/node-red/red.js",
"test": "grunt",
"build": "grunt build",
"dev": "grunt dev",
"build-dev": "grunt build-dev",
"docs": "grunt docs"
I have used npm run start but not showing username password
Ok, I don't often see Node RED being started like that.
can you provide the terminal output that this is producing?
Importantly, what settings file is being loaded, to ensure you have modified the correct one.
npm run start
> node-red@3.1.8 start
28 May 00:24:05 - [info]
Welcome to Node-RED
28 May 00:24:05 - [info] Node-RED version: v3.1.8
28 May 00:24:05 - [info] Node.js version: v18.19.0
28 May 00:24:05 - [info] Darwin 23.1.0 arm64 LE
28 May 00:24:05 - [info] Loading palette nodes
28 May 00:24:06 - [info] Dashboard version 3.6.5 started at /ui
28 May 00:24:06 - [info] Settings file : /Users/glosys/.node-red/settings.js
28 May 00:24:06 - [info] Context store : 'default' [module=memory]
28 May 00:24:06 - [info] User directory : /Users/glosys/.node-red
28 May 00:24:06 - [warn] Projects disabled : editorTheme.projects.enabled=false
28 May 00:24:06 - [info] Flows file : /Users/glosys/.node-red/flows.json
28 May 00:24:06 - [info] Server now running at http://127.0.0.1:1880/
your credentials.
28 May 00:24:06 - [info] Starting flows
MongoNode {
type: 'mongodb',
z: undefined,
g: undefined,
_closeCallbacks: [],
_inputCallback: null,
_inputCallbacks: null,
_expectedDoneCount: 0,
wires: [],
_wireCount: 0,
send: [Function: NOOP_SEND],
credentials: { user: 'admin', password: 'admin' },
hostname: '127.0.0.1',
port: '27017',
db: 'fuel'
type: 'mongodb',
port: '27017',
db: 'fuel',
_users: [ '597e2d3f90b49631' ]
mongodb://admin:admin@127.0.0.1:27017/fuel
28 May 00:24:06 - [info] [mongodb4-client:local-db] client initialized with app name 'nodered-ko1vqcpb'
28 May 00:24:06 - [error] [mongodb4-client:e2bc7ac9aa77279e] MongoMissingCredentialsError: Username required for mechanism 'SCRAM-SHA-256'
28 May 00:24:06 - [error] [mongodb4-client:dd0b7f14421d961d] MongoMissingCredentialsError: Username required for mechanism 'SCRAM-SHA-256'
28 May 00:24:06 - [error] [mongodb out:4] missing mongodb configuration
28 May 00:24:06 - [info] Started flows
So this one
you have modified the adminAuth section?
Ok - You shouldn't be modifying the settings file inside the app its self.
You need to modify this one : /Users/glosys/.node-red/settings.js
the loaded settings file is the one located in ~/.node-red (the users Node RED Directory)
Thanks bro, I found - bahot bahot shukriya (Urdu)
