I threw together a quick way to bridge GPS data from the android app GPS Logger between HomeAssistant and the Nextcloud APP Phonetrack.
Note: Returns the highest http response code thrown by either service, this can result in the GPS logger submitting multiple times if there is any issues with either Nextcloud or HomeAssistant
Extra Nodes used
Configuration
Node-Red
In HomeAssistant follow the instructions found here to obtain the GPS Logger web hook url and add this to the config node
In Nextcloud after creating a tacking session click the link icon and fetch the link labled GpsLogger GET and POST link : and add this to the config node
Edit the http auth Node with your desired credentials.
GPS Logger
Go to Logging details -> Log to custom URL -> URL and add your Node-Red url: https://example.tld/node-red/gps_logger?latitude=%LAT&longitude=%LON&device=[Your_Device_Name_Here]&accuracy=%ACC&battery=%BATT&speed=%SPD&direction=%DIR&altitude=%ALT&provider=%PROV&activity=%ACT×tamp=%TIMESTAMP - Note: edit the url and the [Your_Device_Name_Here]
Go to Logging details -> Log to custom URL -> Basic Authentication add the username and password you set in the http auth node
Exported Config
"id": "d3063735.81fee",
"type": "http in",
"z": "fa05d4c5.666e88",
"name": "GPS Logger endpoint",
"url": "/gps_logger",
"method": "post",
"upload": false,
"swaggerDoc": "",
"x": 120,
"y": 100,
"48a06220.5ce424"
"id": "eb378b88.eb2958",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"targetType": "full",
"x": 1150,
"y": 160,
"id": "40b34f9a.4db0d8",
"type": "http request",
"name": "Home Assistant",
"method": "POST",
"ret": "txt",
"paytoqs": false,
"url": "",
"tls": "",
"proxy": "",
"authType": "",
"x": 600,
"y": 180,
"17f901ca.f3d53e"
"id": "1158aae0.cff345",
"type": "change",
"name": "Build HomeAssistant Query",
"rules": [
"t": "set",
"p": "headers",
"pt": "msg",
"to": "{}",
"tot": "json"
"t": "set",
"p": "headers.content-type",
"pt": "msg",
"to": "application/x-www-form-urlencoded",
"tot": "str"
"t": "set",
"p": "url",
"pt": "msg",
"to": "homeassistant",
"tot": "flow"
"t": "set",
"p": "payload",
"pt": "msg",
"to": "\"latitude=\" & req.query.latitude & \"&longitude=\" & req.query.longitude & \"&device=\" & req.query.device & \"&accuracy=\" & req.query.accuracy & \"&battery=\" & req.query.battery & \"&speed=\" & req.query.speed & \"&direction=\" & req.query.direction & \"&altitude=\" & req.query.altitude & \"&provider=\" & req.query.provider & \"&activity=\" & req.query.activity",
"tot": "jsonata"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 380,
"y": 180,
"40b34f9a.4db0d8"
"id": "8c050501.4c0588",
"type": "change",
"name": "Set Phonetrack URL",
"rules": [
"t": "set",
"p": "url",
"pt": "msg",
"to": "$flowContext(\"phonetrack\") & req.query.device & \"?lat=\" & req.query.latitude & \"&lon=\" & req.query.longitude & \"&acc=\" & req.query.accuracy & \"&speed=\" & req.query.speed & \"&bearing=\" & req.query.direction & \"×tamp=\" & req.query.timestamp & \"&battery=\" & req.query.battery",
"tot": "jsonata"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 360,
"y": 140,
"6ff30b79.a22e7c"
"id": "6ff30b79.a22e7c",
"name": "PhoneTrack",
"method": "POST",
"ret": "txt",
"paytoqs": false,
"url": "",
"tls": "",
"proxy": "",
"authType": "",
"x": 590,
"y": 140,
"17f901ca.f3d53e"
"id": "dca86ae7.b81fb8",
"type": "http response",
"statusCode": "",
"headers": {},
"x": 1150,
"y": 200,
"id": "198786f0.04cbd1",
"type": "config",
"name": "URLS",
"properties": [
"p": "phonetrack",
"pt": "flow",
"to": "https://example.tld/apps/phonetrack/log/gpslogger/__phonetrackid__/",
"tot": "str"
"p": "homeassistant",
"pt": "flow",
"to": "https://home.example.tld/api/webhook/__webhookkey__",
"tot": "str"
"active": true,
"x": 90,
"y": 60,
"id": "17f901ca.f3d53e",
"type": "join",
"mode": "custom",
"build": "array",
"property": "statusCode",
"propertyType": "msg",
"key": "url",
"joiner": "\\n",
"joinerType": "str",
"accumulate": false,
"timeout": "",
"count": "2",
"reduceRight": false,
"reduceExp": "",
"reduceInit": "",
"reduceInitType": "",
"reduceFixup": "",
"x": 790,
"y": 160,
"97160453.f48fa"
"id": "97160453.f48fa",
"type": "change",
"rules": [
"t": "set",
"p": "statusCode",
"pt": "msg",
"to": "$max(statusCode.$number())",
"tot": "jsonata"
"t": "set",
"p": "payload",
"pt": "msg",
"to": "",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 940,
"y": 160,
"7b71caeb.a9fcdc"
"id": "cd4374b1.ed507",
"type": "comment",
"name": "Set URLS for HomeAssistant and PhoneTrack",
"info": "",
"x": 190,
"y": 20,
"id": "7b71caeb.a9fcdc",
"type": "switch",
"rules": [
"t": "gt",
"v": "200",
"vt": "str"
"t": "else"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 970,
"y": 200,
"eb378b88.eb2958",
"dca86ae7.b81fb8"
"dca86ae7.b81fb8"
"id": "48a06220.5ce424",
"type": "node-red-contrib-httpauth",
"file": "",
"cred": "",
"authType": "Basic",
"realm": "",
"username": "",
"password": "",
"hashed": false,
"x": 160,
"y": 140,
"8c050501.4c0588",
"1158aae0.cff345"
I've mirrored this post onto my blog if anyone cares
