Picking a date for display on chart
I'm trying to change the date to view the data collect in other days on my chart, I saw there's this
node called date picker, but I don't know to make it interact with the chart node.
Can anyone give me an idea to make it work?
Typically, the date selected is used in a query to the data source then the newly queried data set is sent to the chart.
For anyone to assist you will need to provide more info.
  • Where is the data stored? in a database? file? memory? other?
  • Explain and show us how you currently populate the chart?
datepicker
as @Steve-Mcl suggests, i store the data in a mysql database and use the picked date in a mysql query where clause to get the data i want.
I save my data in a json file, I don't know how to interact the date picking with the chart to change the date and the data from that day.
Save your chosen date in a flow context variable.
Use a switch node to compare each line from the file with the variable.
You may need a little jiggery-pokery to get the two dates in the same format.
