How can I show the chart from my data?
Hello, Everyone.
I'm happy to know this amazing forum.
I'm stuck in showing node-red dashboard chart from my mysql database;
Database changed
mysql> show tables;
| Tables_in_water_sensor |
| sensor_data |
1 row in set (0.00 sec)
mysql> desc sensor_data;
| Field | Type | Null | Key | Default | Extra |
| id | int | NO | PRI | NULL | auto_increment |
| water_level | float | YES | | NULL | |
| date | date | YES | | NULL | |
3 rows in set (0.03 sec)
mysql> select * from sensor_data;
| id | water_level | date |
| 1 | 12.5 | 2023-06-01 |
| 2 | 13.2 | 2023-06-02 |
| 3 | 11.8 | 2023-06-03 |
| 4 | 10.3 | 2023-06-04 |
| 5 | 12.1 | 2023-06-05 |
function node code
let labels = [];
let data = [];
msg.payload.forEach(row => {
    labels.push(row.date);
    // console.log(`row.date ${row.date.toString()}`);
    data.push(row.water_level);
msg.payload = [
        series: ['Water Level'],
        data: [{
            x: labels,
            y: data.slice(0, labels.length)
        labels: labels
flow json
        "id": "bad3255e28febdae",
        "type": "tab",
        "label": "db",
        "disabled": false,
        "info": "",
        "env": []
        "id": "9d6acaa2d2ed70c7",
        "type": "mysql",
        "z": "bad3255e28febdae",
        "mydb": "5909f0fde201f313",
        "x": 300,
        "y": 180,
                "e07ba751b59c0f58"
        "id": "7264023da74a4a8c",
        "type": "debug",
        "name": "debug 46",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "statusType": "auto",
        "x": 780,
        "y": 200,
        "id": "fd3e944368c16007",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "SELECT * FROM sensor_data",
        "payload": "",
        "payloadType": "date",
        "x": 120,
        "y": 180,
                "9d6acaa2d2ed70c7"
        "id": "e07ba751b59c0f58",
        "type": "function",
        "name": "function 19",
        "func": "let labels = [];\nlet data = [];\n\nmsg.payload.forEach(row => {\n    labels.push(row.date);\n    // console.log(`row.date ${row.date.toString()}`);\n    data.push(row.water_level);\n});\n\nmsg.payload = [\n    {\n        series: ['Water Level'],\n        // data: [{\n        //     x: labels,\n        //     y: data.slice(0, labels.length)\n        // }],\n        labels: labels\n    }\n];\n\n// console.log(`labels.length : ${labels.length}`);\n// console.log(`data.length : ${data.length}`);\n// for (var i = 0; i < data.length; i++)\n// {\n//     console.log(data[i]);\n//     node.send({ payload: data[i] });\n// }\n\n// console.dir(msg);\nreturn msg;\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 550,
        "y": 280,
                "7264023da74a4a8c",
                "a4cf520cba4c62af"
        "id": "a4cf520cba4c62af",
        "type": "ui_chart",
        "group": "aa8eec0d5014b069",
        "order": 1,
        "width": 0,
        "height": 0,
        "label": "chart",
        "chartType": "line",
        "legend": "false",
        "xformat": "HH:mm:ss",
        "interpolate": "linear",
        "nodata": "",
        "dot": false,
        "ymin": "0",
        "ymax": "50",
        "removeOlder": 1,
        "removeOlderPoints": "",
        "removeOlderUnit": "3600",
        "cutout": 0,
        "useOneColor": false,
        "useUTC": false,
        "colors": [
            "#1f77b4",
            "#aec7e8",
            "#ff7f0e",
            "#2ca02c",
            "#98df8a",
            "#d62728",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "outputs": 1,
        "useDifferentColor": false,
        "className": "",
        "x": 790,
        "y": 320,
        "id": "5909f0fde201f313",
        "type": "MySQLdatabase",
        "host": "127.0.0.1",
        "port": "3306",
        "db": "water_sensor",
        "tz": "",
        "charset": "UTF8"
        "id": "aa8eec0d5014b069",
        "type": "ui_group",
        "name": "second",
        "tab": "4f903fa3c7ed98d8",
        "order": 2,
        "disp": true,
        "width": "6",
        "collapse": false,
        "className": ""
        "id": "4f903fa3c7ed98d8",
        "type": "ui_tab",
        "name": "Dashboard2",
        "icon": "dashboard",
        "order": 1,
        "disabled": false,
        "hidden": false
Thank you.
can you connect a debug node to the 'water_sensor' mysql node and copy paste the output here ?
meanwhile, you can also check here
Hello, @smanjunath211
Thank you for your support.
2023. 6. 19. 오후 1:51:26node: debug 46
SELECT * FROM sensor_data : msg : Object
object
_msgid: "d35a8257051c6e35"
payload: array[1]
0: object
series: array[1]
0: "Water Level"
labels: array[45]
[0 … 9]
0: "2023-05-31T15:00:00.000Z"
1: "2023-06-01T15:00:00.000Z"
2: "2023-06-02T15:00:00.000Z"
3: "2023-06-03T15:00:00.000Z"
4: "2023-06-04T15:00:00.000Z"
5: "2023-06-05T15:00:00.000Z"
6: "2023-06-06T15:00:00.000Z"
7: "2023-06-07T15:00:00.000Z"
8: "2023-06-08T15:00:00.000Z"
9: "2023-06-09T15:00:00.000Z"
[10 … 19]
[20 … 29]
[30 … 39]
[40 … 44]
topic: "SELECT * FROM senso
Thank you.
2023. 6. 19. 오후 1:53:14node: debug 46
object
_msgid: "793c5d04db170b17"
payload: array[1]
0: object
series: array[1]
0: "Water Level"
data: array[1]
0: object
x: array[45]
[0 … 9]
[10 … 19]
10: "2023-06-10T15:00:00.000Z"
11: "2023-06-11T15:00:00.000Z"
12: "2023-06-12T15:00:00.000Z"
13: "2023-06-13T15:00:00.000Z"
14: "2023-06-14T15:00:00.000Z"
15: "2023-06-15T15:00:00.000Z"
16: "2023-06-16T15:00:00.000Z"
17: "2023-06-17T15:00:00.000Z"
18: "2023-06-18T15:00:00.000Z"
19: "2023-06-19T15:00:00.000Z"
[20 … 29]
[30 … 39]
[40 … 44]
y: array[45]
labels: array[45]
[0 … 9]
[10 … 19]
[20 … 29]
[30 … 39]
[40 … 44]
topic: "SELECT * FROM sensor_data"
Thank you.
connect a new debug node to the mysql node, i think you are giving the output of debug node to the function node
2023. 6. 19. 오후 2:11:06node: debug 57
SELECT * FROM sensor_data : msg.payload : array[45]
array[45]
[0 … 9]
0: object
water_level: 12.5
date: "2023-05-31T15:00:00.000Z"
1: object
2: object
3: object
4: object
5: object
6: object
7: object
8: object
9: object
[10 … 19]
10: object
water_level: 13.4
date: "2023-06-10T15:00:00.000Z"
11: object
12: object
13: object
14: object
Thank you.
I am not an expert in writing answers, and the data you provided is not in an usable format. if you could give me sample data, it would be better. sorry if i am misguiding you.
however, try this and see if it works.
[{"id":"e0d895986048fb46","type":"mysql","z":"370cbf905893daf4","mydb":"c966bba326b387f9","name":"","x":300,"y":180,"wires":[["e93a8de06a8b3c52","3eb465c7a9a238d4"]]},{"id":"ca868da90caccc4a","type":"inject","z":"370cbf905893daf4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"SELECT * FROM sensor_data","payload":"","payloadType":"date","x":120,"y":180,"wires":[["e0d895986048fb46"]]},{"id":"e93a8de06a8b3c52","type":"function","z":"370cbf905893daf4","name":"function 19","func":"let labels = [];\nlet data = [];\n\nmsg.payload.forEach(row => {\n    labels.push(row.date);\n    // console.log(`row.date ${row.date.toString()}`);\n    data.push(row.water_level);\n});\n\nmsg.payload = [\n    {\n        series: ['Water Level'],\n        // data: [{\n        //     x: labels,\n        //     y: data.slice(0, labels.length)\n        // }],\n        labels: labels\n    }\n];\n\n// console.log(`labels.length : ${labels.length}`);\n// console.log(`data.length : ${data.length}`);\n// for (var i = 0; i < data.length; i++)\n// {\n//     console.log(data[i]);\n//     node.send({ payload: data[i] });\n// }\n\n// console.dir(msg);\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":550,"y":280,"wires":[["39c998e474e3ed67"]]},{"id":"3eb465c7a9a238d4","type":"function","z":"370cbf905893daf4","name":"Prepare Bar Graph Data","func":"let mname = \"some series\"\nlet dataC = [[]];\nlet dataLabels = [];\n\nfor (let X in msg.payload) {\n    dataLabels[X] = msg.payload[X].date;\n    dataC[0][X] = msg.payload[X].water_level;\n}\n\nvar m = {\n    \"series\": [{mname}],\n    \"data\": dataC,\n    \"labels\": dataLabels\n};\n\nreturn { payload: [m] };\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":430,"y":510,"wires":[["36c29e42700861f5"]]},{"id":"39c998e474e3ed67","type":"debug","z":"370cbf905893daf4","name":"debug 46","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":780,"y":200,"wires":[]},{"id":"36c29e42700861f5","type":"change","z":"370cbf905893daf4","name":"Set Graph Title","rules":[{"t":"set","p":"mname","pt":"msg","to":"'Chart Title'","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":680,"y":510,"wires":[["c46c6d4a554b2165"]]},{"id":"c46c6d4a554b2165","type":"ui_chart","z":"370cbf905893daf4","name":"","group":"aa8eec0d5014b069","order":1,"width":0,"height":0,"label":"chart","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"0","ymax":"50","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"className":"","x":880,"y":510,"wires":[[]]},{"id":"c966bba326b387f9","type":"MySQLdatabase","name":"","host":"127.0.0.1","port":"3306","db":"water_sensor","tz":"","charset":"UTF8"},{"id":"aa8eec0d5014b069","type":"ui_group","name":"second","tab":"4f903fa3c7ed98d8","order":2,"disp":true,"width":"20","collapse":false,"className":""},{"id":"4f903fa3c7ed98d8","type":"ui_tab","name":"Dashboard2","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
It works fine.
Could you tell me what is my mistake more detail?
Thank you.
Could you help me wide x - axis in chart on dashboard?
It grows vertically.
Don't span widely. it fixed 6 in width.
Thank you.
I solved this by myself.
Thank you.
the syntax expected by chart node was not correct.
Thank you so much.
glad we could help.
close the thread if you are satisfied with the solution by marking one of the post as solution.
