Problem getting data from mysql db to line chart
Hi!
Im a beginner and still learning NodeRed.
I have browsed through the forums to try to find information.
However Im stuck.
I have a table in the database that I want to pull some data from.
each line from the database query looks like this:
time: "2022-09-20T07:58:55.000Z"
outdoortemperature: 13
loggedoutdoortemp: 10
What I want the line chart to show
is how the two temperatures change and corelate over time.
I have created a change node with a J:expression (found that in a tutorial)
This is my J:expression code:
[{"series" : [$distinct(time)],
    "data":$each(payload{time:loggedoutdoortemp},function($val){$val})
I know it probably doesnt make any sense at all but this is the closest I got to something that looks like what I understood is needed in the spec.
However, when I use this in nodered Im getting a
""Invalid JSONata expression: Key in object structure must evaluate to a string; got: "2022-09-20T07:58:55.000Z"" error message.
And now Im completely stuck.
Any ideas how to get forward?
Thanks for all help and sorry if my post is messy.
/N
You could probably adapt this dynamic routine with little ease...
    "series": [""],
    "labels": [""],
    "data": [[payload.{
        "x": datetime,
        "y": $."m"
this works for me.
Hi, yeah, that gave me a list of the timestamps.
Not sure I follow "where" to add the rest of the data though (temperatures)
I take it you want to plot two lines, outdoor and logged?
If so then the jsonata would be
$lines := ["outdoortemperature","loggedoutdoortemp"];
       "series": $lines,
       "data":[
            $lines.[($key := $;
                $$.payload.{"x": $.time, "y": $lookup($, $key)}
       "labels":[]
YES! Fantastic!
Thank you very much, worked like a charm!
