Display line chart with data retrieved from mysql
can someone help me? im new with node-red. i want to display line chart for my data but seems like somethings wrong because the line won't appear. here is my flow
        "id": "965463562375cf7e",
        "type": "mysql",
        "z": "bae0fa13bc192bb4",
        "mydb": "69487da61920f155",
        "name": "cradle db",
        "x": 1080,
        "y": 400,
                "dbd533965af4947e",
                "91d58826a42d052e"
        "id": "311edb1ffde2125f",
        "type": "function",
        "name": "insert into chart",
        "func": "msg.topic = `\n        SELECT frequency, DateTime \nFROM movement_frequency \nWHERE DateTime >= NOW() - INTERVAL 1 HOUR;\n\n\n    `;\n\n// Return the message with the query\nreturn msg;\n\n",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 980,
        "y": 340,
                "773ba03cf3933d04",
                "965463562375cf7e"
        "id": "dbd533965af4947e",
        "type": "function",
        "name": "combiforchart",
        "func": "const inp = msg.payload;\n\n// Create an empty chart object\nvar outObj = [{\n    series: [\"Frequency\"],  // Line label\n    data: [[]],  // Chart data structure\n    labels: []   // Chart labels\n}];\n\n// Fill chart object with data\nfor (let item of inp) {\n    const date = new Date(item.DateTime); // Convert DateTime to Date object\n    \n    // Check if the date is invalid\n    if (isNaN(date)) {\n        node.warn(`Invalid Date for item: ${JSON.stringify(item)}`);\n        continue; // Skip this item if the date is invalid\n    }\n\n    // Ensure x is formatted as HH:mm (you may use other formats)\n    const xValue = date.toLocaleTimeString([], { hour: '2-digit', minute: '2-digit' });\n    \n    // Add data point to the chart\n    outObj[0].data[0].push({ x: xValue, y: item.frequency || 0 });\n    \n    // Optionally add labels (not used in x/y chart but for reference)\n    outObj[0].labels.push(xValue);\n}\n\n// Assign the formatted chart object to the message payload\nmsg.payload = outObj;\n\n// Set the topic to ensure the line label is used in the chart\nmsg.topic = \"Motion\";  // You can change this to whatever label you prefer for the line\n\nreturn msg;\n",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1300,
        "y": 480,
                "3906731b6640319b"
        "id": "91d58826a42d052e",
        "type": "debug",
        "name": "debug 32",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "",
        "statusType": "auto",
        "x": 1260,
        "y": 600,
        "id": "3bd8483f9deb09e1",
        "type": "mysql",
        "x": 860,
        "y": 400,
                "311edb1ffde2125f"
        "id": "773ba03cf3933d04",
        "type": "debug",
        "name": "debug 30",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "x": 1160,
        "y": 340,
        "id": "3906731b6640319b",
        "type": "ui_chart",
        "group": "ab32e6f0245d4ae1",
        "order": 1,
        "width": "22",
        "height": "4",
        "label": "Movement Frequency",
        "chartType": "line",
        "legend": "true",
        "xformat": "HH:mm",
        "interpolate": "linear",
        "nodata": "no data available",
        "dot": false,
        "ymin": "",
        "ymax": "",
        "removeOlder": 1,
        "removeOlderPoints": "",
        "removeOlderUnit": "3600",
        "cutout": 0,
        "useOneColor": false,
        "useUTC": false,
        "colors": [
            "#1f77b4",
            "#aec7e8",
            "#ff7f0e",
            "#2ca02c",
            "#98df8a",
            "#d62728",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "outputs": 1,
        "useDifferentColor": false,
        "className": "",
        "x": 1500,
        "y": 480,
                "36354d0080905ced"
        "id": "e3757c85f85920e2",
        "type": "function",
        "name": "insert into database",
        "func": "if (Array.isArray(msg.payload) && msg.payload.length > 0) {\n    let frequency = msg.payload[0].frequency || 0; // Default to 0 if undefined\n    msg.topic = `\n        INSERT INTO movement_frequency (DateTime, frequency)\n        VALUES (NOW(), ${frequency})\n    `;\n    msg.payload = frequency;\n    return msg;\n} else {\n    // If no data, insert 0\n    msg.topic = `\n        INSERT INTO movement_frequency (DateTime, frequency)\n        VALUES (NOW(), 0)\n    `;\n    msg.payload = 0;\n\n    node.warn(\"ResultSetHeader: \" + JSON.stringify(msg.payload));\n    \n    return msg;\n}\n",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 710,
        "y": 340,
                "3bd8483f9deb09e1"
        "id": "36354d0080905ced",
        "type": "debug",
        "name": "debug 35",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1680,
        "y": 480,
        "id": "72cd8bed3cf1e1f8",
        "type": "mysql",
        "x": 520,
        "y": 340,
                "e3757c85f85920e2"
        "id": "8db5d2a5ab316b2d",
        "type": "function",
        "name": "create query audio",
        "func": "msg.topic = `\n    SELECT COUNT(*) AS frequency, DateTime\n    FROM movement\n    WHERE DateTime >= NOW() - INTERVAL 1 MINUTE\n    GROUP BY HOUR(DateTime), MINUTE(DateTime);\n\n`;\nreturn msg;\n",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 310,
        "y": 340,
                "72cd8bed3cf1e1f8"
        "id": "e5090132986e7610",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "60",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 90,
        "y": 340,
                "8db5d2a5ab316b2d"
        "id": "0a013b8c4eb3631a",
        "type": "ui_button",
        "order": 2,
        "width": 0,
        "height": 0,
        "passthru": false,
        "label": "button",
        "tooltip": "Load Data from Database",
        "color": "",
        "bgcolor": "",
        "className": "",
        "icon": "",
        "payload": "",
        "payloadType": "str",
        "topic": "payload",
        "topicType": "msg",
        "x": 110,
        "y": 420,
                "8db5d2a5ab316b2d"
        "id": "69487da61920f155",
        "type": "MySQLdatabase",
        "name": "cradle",
        "host": "127.0.0.1",
        "port": "3306",
        "db": "cradle",
        "tz": "",
        "charset": "UTF8"
        "id": "ab32e6f0245d4ae1",
        "type": "ui_group",
        "name": "Motion Frequency",
        "tab": "899250cf6621fe0f",
        "order": 1,
        "disp": true,
        "width": "22",
        "collapse": false,
        "className": ""
        "id": "899250cf6621fe0f",
        "type": "ui_tab",
        "name": "Data Visualization",
        "icon": "dashboard",
        "order": 4,
        "disabled": false,
        "hidden": false
i'll provide the dashboard and the debugs too just for review
your code is unreadable / cannot copy.
please use backticks to wrap your code.
In order to make code readable and usable it is necessary to surround your code with three backticks (also known as a left quote or backquote ```)
   code goes here
You can edit and correct your post by clicking the pencil :pencil2: icon.
I am assuming you are using dashboard 1 since i see /ui in the browser.
copy paste the debug 32 output and the contents of the function node just before the chart node.
thanks for informing, here's the debug 32 output
1/9/2025, 11:32:20 PMnode: debug 32
SELECT frequency, DateTime FROM movement_frequency WHERE DateTime >= NOW() - INTERVAL 1 HOUR; : msg.payload : array[99]
array[99]
[0 … 9]
[10 … 19]
[20 … 29]
[30 … 39]
[40 … 49]
[50 … 59]
[60 … 69]
[70 … 79]
[80 … 89]
[90 … 98]
90: object
91: object
92: object
93: object
94: object
95: object
96: object
97: object
98: object
frequency: 8
DateTime: "2025-01-09T15:32:20.000Z"
Your code is still cannot be copied as valid json.
read the docs on how to paste a flow.
can you share debug output in an inject node? copy the value from the debug.
There’s a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path/value for any data item.
BX00Cy7yHi
i have updated the flow. hopefully it can be copied now.
for the inject node, do you mean the button node? sorry if i'm slow to catch since i'm still new to this
If you are new with Node-red you would be much better off using @flowfuse/node-red-dashboard aka dashboard 2.
Not only is the dashboard you have installed deprecated but db2 makes it much much easier to draw a chart from an sql query.
thank you for the suggestion ^^ i appreciated it. i installed this version as my lecturer asked me too. but i can configure it now!
