MYSQL database to chart
Hi everyone,
I'm tryign to make a chart with the data in a mysql database. The database name is "prueba" and the table name is "prueba" too. When I deploy the flow the chart is blank and I don't know whats wrong.
This is the flow:
[{"id":"42ac8bd2.5ce6d4","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"a65cd334.88fbc","type":"mysql","z":"42ac8bd2.5ce6d4","mydb":"6b117fd6.12162","name":"","x":300,"y":200,"wires":[["93262868.006e78"]]},{"id":"f05703c7.1631c","type":"ui_chart","z":"42ac8bd2.5ce6d4","name":"","group":"ca30b7ae.d36008","order":1,"width":0,"height":0,"label":"chart","chartType":"line","legend":"false","xformat":"auto","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"604800","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"x":550,"y":200,"wires":[["e2ec0bee.b98938"]]},{"id":"e2ec0bee.b98938","type":"debug","z":"42ac8bd2.5ce6d4","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":730,"y":140,"wires":[]},{"id":"93262868.006e78","type":"change","z":"42ac8bd2.5ce6d4","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"[ { \"key\": \"AMB_T\", \"values\": msg.payload.[epoch, AMB_T] } ]","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":430,"y":140,"wires":[["f05703c7.1631c"]]},{"id":"bab911cb.28d1b","type":"inject","z":"42ac8bd2.5ce6d4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"select * from prueba","payload":"","payloadType":"date","x":130,"y":180,"wires":[["a65cd334.88fbc"]]},{"id":"6b117fd6.12162","type":"MySQLdatabase","name":"","host":"127.0.0.1","port":"3306","db":"prueba","tz":"","charset":"UTF8"},{"id":"ca30b7ae.d36008","type":"ui_group","name":"Informe","tab":"e69e034.ca863","order":1,"disp":true,"width":"6","collapse":false},{"id":"e69e034.ca863","type":"ui_tab","name":"Grafico","icon":"dashboard","disabled":false,"hidden":false}]
I will Include also a photo of the database. I want to make a line chart with the values in AMB_T column.
Welcome to the forum @victorramos99
In order to make code more readable and importable it is important to surround your code with three backticks
like this
You can edit and correct your post by clicking the pencil icon.
Feed the data that you are giving to the database into a debug node and compare it with the required format described in node-red-dashboard/Charts.md at master · node-red/node-red-dashboard · GitHub
If you are a complete beginner with node-red then I recommend watching this playlist: Node-RED Essentials. The videos are done by the developers of node-red. They're nice & short and to the point. You will understand a whole lot more in about 1 hour. A small investment for a lot of gain.
If you search the forum for the title of your question it will find a number of hits that may be helpful.
If you are still stuck after that then come back and tell us which bit you have having difficulty with.
I have compared my data with the required format that shows in the links and I could solve the problem.
Thank you for your time Colin! :slight_smile:
