Ping node:
Is there any method to pass in the host ip address of the Ping target?
We are hardcoding in the PING address and that works ok, but looking for a way to feed in the ip address via msg.
THank you
Ping node:
THank you
...and which ping node are you using????
Thank you- the Ping node we are using is the one under the 'Network' .
That doesn't help identify it. What npm module did you install to get that node?
There are at least 4 on the flows.nodered.org site. One must do what you want...
Thank you. I had the Node Red from the Raspbian install.
Will try one of the PING-Configurable in the Node Library
Thank you
??? How were you doing the ping in the first place?
The Ping Node that was installed only allowed for 'hardcoded' IP address.
are you talking about a node-red node? ot a node.js node?
node-red-node-ping
0.0.15
I didn't think that a ping node was installed in a vanilla node-RED Raspbian installation?
Have you added one to the palette?
No there is no base ping, but if you search the flows you will find some. Always a good idea to do a search for existing flows.
Need some asstance:
Went to Palette Manger in Node Red
Searched for and found this alternative PING node which looks like it would work.
node-red-configurable-ping
A Node-RED node which takes input and pings a remote server.
Pressed Installed, but failed to install?
Any suggestions?
What did it say, what does the log say?
Hi @sweetwater - the lack of feedback in the editor when an install fails is a known issue we're resolving in the next release.
You may need to drop to the command line and run npm install node-red-configurable-ping manually in ~/.node-red to get the full details.
Thank Nick and team.
It turns out that the install under the Palette Manager worked.
The problem was user mistake- we had our Pi computer on a static IP for our application and that was not getting thru.
