Play simple audio with ui_template (Dashboard 2)
I am trying to play simple audio in ui_template, I try the following:
<template>
    <div>
        <vuetify-audio :file="file" :ended="audioFinish"></vuetify-audio>
    </div>
</template>
<script>
export default {
    data() {
        return {
            file: 'http://www.noiseaddicts.com/samples_1w72b820/290.mp3',
        components: {
            'vuetify-audio': VuetifyAudio
         If you want to use ended callback add below code
            methods: {
                audioFinish () {
</script>
It doesn't work for me.
Is there a simple way to do this? I'm just looking for an alert to be played (audio output).
Can anyone guide me? The idea is to see an alternative way to run an audio alarm (Audio output).
this is not a built in vuetify component.
I suspect you picked this up on a web search.
the vuetify-audio itself uses a regular html5 audio element under the hood - so just do that instead.
I'm trying to play an audio by taking the msg.payload, but it doesn't work.
<template>
    <div :class="msg.payload" id="msg">
        <audio id="myAudio">
            <source src="https://media.geeksforgeeks.org/wp-content/uploads/20240218213800/CantinaBand60.wav"
                type="audio/mpeg">
            Your browser does not support the audio element.
        </audio>
    </div>
</template>
{{msg.payload}}
<script>
    var audio = document.getElementById("myAudio");
    function saludo(mensaje) {
        audio.play();
    (function (scope) {
        scope.$watch('msg.payload', function(newValue){
            document.getElementById('myDiv').innerHTML = "valor" + newValue;
            if (newValue === 'Hola'){
                saludo(mensaje);
    }) (scope);
</script>
Not surprising your html looks (nearly) right but the code is littered with old Angular JS (AKA old depreciated Dashboard 1.0) stuff i.e. scope.$watch etc!
There are clear docs and live demos on the @flowfuse/dashboard site that show you the different ways to pass data to the template. Template ui-template | Node-RED Dashboard 2.0
Never mind.
Here is a working demo
<template>
    <!-- if you remove the `controls` attribute, you MUST click soomething on the page before initiating play -->
    <audio ref="audio" controls autoplay src=""> </audio>
</template>
<script>
    export default {
        watch: {
            msg: function () {
                if (this.msg?.topic === 'play') {
                    if (this.$refs.audio.src !== this.msg.payload ) {
                        this.$refs.audio.src = this.msg.payload
                    this.$refs.audio.play()
                } else if (this.msg?.topic === 'stop') {
                    this.$refs.audio.src = ''
                } else if (this.msg?.topic === 'pause') {
                    this.$refs.audio.pause()
</script>
<style>
.hidden {
    display: none !important;
</style>
Full working flow (CTRL-I to import)
[{"id":"6a137c41d3addec5","type":"ui-template","z":"3567e03e18126502","group":"d3197b4c4dd7b057","page":"","ui":"","name":"","order":2,"width":0,"height":0,"head":"","format":"<template>\n    <!-- if you remove the `controls` attribute, you MUST click soomething on the page before initiating play -->\n    <audio ref=\"audio\" controls autoplay src=\"\"> </audio>\n</template>\n\n<script>\n    export default {\n        watch: {\n            msg: function () {\n                if (this.msg?.topic === 'play') {\n                    if (this.$refs.audio.src !== this.msg.payload ) {\n                        this.$refs.audio.src = this.msg.payload\n                    }\n                    this.$refs.audio.play()\n                } else if (this.msg?.topic === 'stop') {\n                    this.$refs.audio.src = ''\n                } else if (this.msg?.topic === 'pause') {\n                    this.$refs.audio.pause()\n                }\n            }\n        }\n    }\n</script>\n\n<style>\n.hidden {\n    display: none !important;\n}\n</style>","storeOutMessages":true,"passthru":true,"resendOnRefresh":true,"templateScope":"local","className":"hidden","x":320,"y":340,"wires":[[]]},{"id":"caf334102ab7952d","type":"inject","z":"3567e03e18126502","name":"cantina","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"play","payload":"https://media.geeksforgeeks.org/wp-content/uploads/20240218213800/CantinaBand60.wav","payloadType":"str","x":170,"y":380,"wires":[["6a137c41d3addec5"]]},{"id":"8e135a0e9bfdccb7","type":"inject","z":"3567e03e18126502","name":"march","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"play","payload":"https://www2.cs.uic.edu/~i101/SoundFiles/ImperialMarch60.wav","payloadType":"str","x":170,"y":340,"wires":[["6a137c41d3addec5"]]},{"id":"3c290f1ea6cf8b36","type":"inject","z":"3567e03e18126502","name":"pause","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"pause","x":170,"y":300,"wires":[["6a137c41d3addec5"]]},{"id":"436efb1217534529","type":"inject","z":"3567e03e18126502","name":"stop","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"stop","x":170,"y":260,"wires":[["6a137c41d3addec5"]]},{"id":"d3197b4c4dd7b057","type":"ui-group","name":"P2 G1","page":"6685af11067a04cd","width":11,"height":"1","order":1,"showTitle":true,"className":"","visible":"true","disabled":"false","groupType":"default"},{"id":"6685af11067a04cd","type":"ui-page","name":"grid page","ui":"22ea43815413e748","path":"/page2","icon":"home","layout":"grid","theme":"70e58855f40712e7","breakpoints":[{"name":"Default","px":"0","cols":"3"},{"name":"Tablet","px":"576","cols":"6"},{"name":"Small Desktop","px":"768","cols":"9"},{"name":"Desktop","px":"1024","cols":"12"}],"order":2,"className":"","visible":"true","disabled":"false"},{"id":"22ea43815413e748","type":"ui-base","name":"base","path":"/dashboard","appIcon":"","includeClientData":true,"acceptsClientConfig":["ui-notification","ui-control"],"showPathInSidebar":false,"showPageTitle":true,"navigationStyle":"icon","titleBarStyle":"default"},{"id":"70e58855f40712e7","type":"ui-theme","name":"pink Theme","colors":{"surface":"#ffffff","primary":"#d355a5","bgPage":"#e1bcbc","groupBg":"#fbe9e9","groupOutline":"#dc8f8f"},"sizes":{"density":"compact","pagePadding":"12px","groupGap":"12px","groupBorderRadius":"4px","widgetGap":"12px"}}]
note
You must click somewhere inside the page before starting a playback. This is a browser thing.
Thank you very much, I've been struggling with this for several days.
