How to control HTML5 Audio Element from UI-Template?
I'm a newbie.
Would like some example code to get DOM Audio element basic custom control (play() / pause() methods from a button or clickable image) on HTML5 audio element rendered in browser.
I succeed to play audio file from audio controller with "autoplay" or "controls" properties sets in ui-template:
	<audio id="myaudio" src="myaudio_url" autoplay>
            Your browser does not support the
            <code>audio</code> element.
 </audio>
or
<audio id="myaudio" src="myaudio_url" controls>
    </audio>
Unfortunately don't know how to script play() / pause () methods from a custom button in NR UI-template.
Any help welcome.
Thank's
Hi Herold,
Welcome to the forum!
Normally - unless I have something misunderstood about your case - you can use the ui_audio node (which is part of the dashboard node set) for this. Here is more information. Although pauzing is not possible this way (see here)...
Bart
