when the plc is offline the flow stops, instead I would like to write the number "-1" in the following nodes, how could I do this?
Thanks very much for your help.
Use a status node to monitor the status of them nodes
Its relatively straightforward.
Give it a go & come back if you get stuck.
Alternatively - or complementary to that - you could use a trigger node configured as a watchdog timer. That could send you a -1 if no message has been received for a specific amount of time.
