When the connection status variable of node S7 is false, I want to send the values to 0 of all the variables that it has configured
Hello everybody!
I am needing that when the connection state of the S7 node is offline (attachment 1) I want to send the values to -1 to some specific variables that I have created inside the node.
This is because we need to log and visualize when the problem occurs in the PLC.
I don't know how to call the variable that identifies the state of the S7 node.
Thank you very much!
Shortcut: node-red-contrib-s7
Captura de pantalla 2023-05-30 124957
Have you tried using a status node set to monitor the s7 node, this should give some output that may help you, if the s7 node is compliant with the status node. Or possibly a catch node may work.
