Hi! I'm newbie to Node-Red but anyway, here is my question:
Why s7 in node keeps connecting although node is disabled..
In Powershell every ~10seconds is "Error: Timeout to connecting to the transport"..
P.S. So far didnt find any way to add the screenshot
Does the node have a config node? Did you disable that?
Look in the list of config nodes in the sidebar. Or use the search (ctrl-f)
What does the edit panel show when you open the s7 node?
Yes, I know. At my first post I wrote "... Why s7 in node keeps connecting although node is disabled.."
Screenshot is from Enabled version
Node consists of two parts:
1.Connection initialization
2.Variables declaration and translation from string to addresses to start polling the values.
If node is disabled, only second part is disabled, but endpoint which control connection is still working.
to prevent errors from appearing you need to disable s7 endpoint
OK, Thanks!
Didnt know that there is such config.
I'm using node-red just for one week
