I have exported the flow, in notepade I find the node ID. But I can't as a new user upload the file. So it's placed here:
[{"id":"6c23acd6.00a0c4","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"e768e368.f8cd28","type":"s7 endpoint","z":"","transport":"iso-on-tcp","address":"192.168.130.23","port":"102","rack":"0","slot":"1","localtsaphi":"01","localtsaplo":"00","remotetsaphi":"01","remotetsaplo":"00","connmode":"rack-slot","adapterauto":true,"adapterport":"","busaddr":"2","adapteraddr":"0","cycletime":"10000","timeout":"5000","verbose":"default","name":"","vartable":[{"addr":"DB26,REAL0","name":"T1_Abgabe"}]},{"id":"742b85b7.f0debc","type":"ui_tab","z":"","name":"Home","icon":"dashboard","disabled":false,"hidden":false},{"id":"6e60af29.6fcd2","type":"ui_group","z":"","name":"Kühlwasser","tab":"742b85b7.f0debc","disp":false,"width":"6","collapse":false},{"id":"78255b7b.2b4f64","type":"ui_base","theme":{"name":"theme-dark","lightTheme":{"default":"#0094CE","baseColor":"#0094CE","baseFont":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif","edited":true,"reset":false},"darkTheme":{"default":"#097479","baseColor":"#aeae00","baseFont":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif","edited":true,"reset":false},"customTheme":{"name":"Untitled Theme 1","default":"#4B7930","baseColor":"#4B7930","baseFont":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif"},"themeState":{"base-color":{"default":"#097479","value":"#aeae00","edited":true},"page-titlebar-backgroundColor":{"value":"#aeae00","edited":false},"page-backgroundColor":{"value":"#111111","edited":false},"page-sidebar-backgroundColor":{"value":"#ffffff","edited":false},"group-textColor":{"value":"#fafa00","edited":false},"group-borderColor":{"value":"#555555","edited":false},"group-backgroundColor":{"value":"#333333","edited":false},"widget-textColor":{"value":"#eeeeee","edited":false},"widget-backgroundColor":{"value":"#aeae00","edited":false},"widget-borderColor":{"value":"#333333","edited":false},"base-font":{"value":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif"}},"angularTheme":{"primary":"indigo","accents":"blue","warn":"red","background":"grey"}},"site":{"name":"Celebrate Records","hideToolbar":"false","allowSwipe":"false","lockMenu":"true","allowTempTheme":"true","dateFormat":"DD/MM/YYYY","sizes":{"sx":48,"sy":48,"gx":6,"gy":6,"cx":6,"cy":6,"px":0,"py":0}}},{"id":"32d0288f.c95fb","type":"s7 in","z":"6c23acd6.00a0c4","endpoint":"e768e368.f8cd28","mode":"all","variable":"","diff":false,"name":"","x":154.5,"y":66,"wires":[["4f6166e7.0f94d8"]]},{"id":"be3bcecc.8a7f8","type":"ui_gauge","z":"6c23acd6.00a0c4","name":"","group":"6e60af29.6fcd2","order":0,"width":0,"height":0,"gtype":"gage","title":"","label":"","format":"{{msg.payload | number:1}}°C","min":"10","max":"40","colors":["#ca0000","#00ca00","#ca0000"],"seg1":"20","seg2":"23","x":631.5,"y":169,"wires":[]},{"id":"4f6166e7.0f94d8","type":"split","z":"6c23acd6.00a0c4","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":394.5,"y":172,"wires":[["be3bcecc.8a7f8","e55ece13.850f38"]]},{"id":"e55ece13.850f38","type":"ui_chart","z":"6c23acd6.00a0c4","name":"","group":"6e60af29.6fcd2","order":1,"width":0,"height":0,"label":"Kühlwasser Abgabe","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"waiting for data ...","dot":false,"ymin":"19","ymax":"25","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":688.5,"y":212,"wires":[[]]}]
It comes from the endpoint S7: "id":"e768e368.f8cd28","type":"s7 endpoint",
Do I have forgot something to configure for this endpoint?
