Hi. I'm using node-red v3.0.2 and node-red-dashboard module.
I want to show a group of text input dashboard nodes (a list of options) in a pop-up window.
I found a solution (but haven't tested it yet) - use dashboard notification node and iframe with custom window dialog size but is there a more proper way to do this?
Modern browsers have dialog(+modal) element which would be best.
In a ui-template node you could use the Angular.js service $mdDialog. This could be a start:
<script>
(function(scope){
var testShowAlert = function ($mdDialog) {
var alert = $mdDialog.alert({
title: 'Attention',
textContent: 'This is an example of how simple dialogs can be!',
ok: 'Close'
$mdDialog
.show( alert )
.finally(function() {
alert = undefined;
var testShowDialog = function ($mdDialog) {
const ctrl = DialogController;
const parentEl = angular.element(document.body);
$mdDialog.show({
parent: parentEl,
template:
'<md-dialog aria-label="List dialog">' +
' <md-dialog-content>'+
' <md-list>'+
' <md-list-item ng-repeat="item in ctrl.items">'+
' <p>Number {{item}}</p>' +
' </md-list-item></md-list>'+
' </md-dialog-content>' +
' <md-dialog-actions>' +
' <md-button ng-click="ctrl.closeDialog()" class="md-primary">' +
' Close Dialog' +
' </md-button>' +
' <md-button ng-click="ctrl.sendMsg()" class="md-primary">' +
' Send Message' +
' </md-button>' +
' </md-dialog-actions>' +
'</md-dialog>',
locals: {
items: ctrl.items
controller: DialogController,
controllerAs: 'ctrl'
function DialogController($mdDialog) {
this.items = [124, 2345, 5678];
this.closeDialog = function() {
$mdDialog.hide();
this.sendMsg = function() {
scope.send({payload:'my message'});
scope.showAlert = function() {
var injector = angular.element("#nr-dashboard").injector();
injector.invoke(testShowAlert,null,null);
scope.showDialog = function($event) {
console.log(injector);
injector.invoke(testShowDialog,null,null);
})(scope);
</script>
<button ng-click="showAlert()">Test Alert</button>
<button ng-click="showDialog($event)">Test Dialog</button>
