Dashboard UI node in popup
Hi folks,
Via a Template-node it is possible to show html content in a popup dialog.
However I was now wondering if it is also possible to show a UI node (node-red-contrib-ui-xxxxxx) in a modal popup dialog, i.e. on top of the other dashboard widgets.
I expect the answer consists out of two letters only: starting with "N" and ending with "O" ...
Thanks!!
Bart
Well, in this case your expectation isn't right.
The answer ends with 'possible' and starts with 'im'.
