This is really crude, but it might give you ideas you can use without resorting to a template node or custom API.
[{"id":"57e0f48f.2095cc","type":"inject","z":"f63bb00e.623cd8","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":true,"onceDelay":0.1,"x":110,"y":80,"wires":[["7bc2234f.756184"]]},{"id":"7bc2234f.756184","type":"change","z":"f63bb00e.623cd8","name":"","rules":[{"t":"set","p":"options","pt":"msg","to":"['fruits','vegetables','drinks']","tot":"jsonata"},{"t":"set","p":"payload","pt":"msg","to":"fruits","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":220,"y":140,"wires":[["3bcb1d68.454592"]]},{"id":"3bcb1d68.454592","type":"ui_dropdown","z":"f63bb00e.623cd8","name":"","label":"","tooltip":"","place":"Select option","group":"2f028802.e68d","order":1,"width":0,"height":0,"passthru":true,"options":[{"label":"","value":"","type":"str"}],"payload":"","topic":"","x":390,"y":140,"wires":[["fe9c6f12.2e1cc"]]},{"id":"fe9c6f12.2e1cc","type":"switch","z":"f63bb00e.623cd8","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"fruits","vt":"str"},{"t":"eq","v":"vegetables","vt":"str"},{"t":"eq","v":"drinks","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":450,"y":220,"wires":[["f49503bd.72a76"],["b7303574.28e768"],["f8d4e225.5471f"]]},{"id":"f49503bd.72a76","type":"change","z":"f63bb00e.623cd8","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"[{'title':'apples'},{'title':'bananas'},{'title':'oranges'}]","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":620,"y":180,"wires":[["118429a4.b9a3b6"]]},{"id":"b7303574.28e768","type":"change","z":"f63bb00e.623cd8","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"[{'title':'maize'},{'title':'beans'},{'title':'squash'}]","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":620,"y":220,"wires":[["118429a4.b9a3b6"]]},{"id":"f8d4e225.5471f","type":"change","z":"f63bb00e.623cd8","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"[{'title':'beer'},{'title':'wine'},{'title':'water'}]","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":620,"y":260,"wires":[["118429a4.b9a3b6"]]},{"id":"118429a4.b9a3b6","type":"ui_list","z":"f63bb00e.623cd8","group":"2f028802.e68d","name":"","order":2,"width":"0","height":"0","lineType":"two","actionType":"click","allowHTML":false,"x":790,"y":220,"wires":[["bb4e2eca.92bcd"]]},{"id":"bb4e2eca.92bcd","type":"debug","z":"f63bb00e.623cd8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":930,"y":220,"wires":[]},{"id":"2f028802.e68d","type":"ui_group","z":"","name":"Test","tab":"cb94cd6.524bd3","order":2,"disp":true,"width":"6","collapse":false},{"id":"cb94cd6.524bd3","type":"ui_tab","z":"","name":"NR Discussion","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
The dashboard ui_list node could be replaced by ui_form, if the user needs to add new information rather than just make a selection.
