Using an HTML form in a Dashboard Template node
I’ve got an application where I need to pre-load a form so I can use it to edit existing data, or create new data. The Form node currently doesn’t provide an input.
As a result, my approach was to build an HTML form in a Template Node. I’ve got it done, pre-populating, and working. The Template node displays the form in the dashboard alongside other dashboard nodes.
Now I’m realizing I wasn’t thinking about how I was going to get the data into msg.payload on a SUBMIT. I’m thinking now that I shouldn’t have gone down this path, since I’m still trying to use the dashboard at this point.
Really what I wanted to do was simply pre-load the Form Node. Then take the results and use them to do the rest of my processing. I suppose I could use dashboard Text inputs instead of a form.
My question, is… Can someone help me figure out how to go from a custom HTML form inside the dashboard within a Template Node to data inside the msg object?
I’m kind of stumped?. Thanks in advance for your help.
this is as close as you can get right now.
help me figure out the save function please
[{"id":"328a7269.1b93de","type":"ui_template","z":"48f8ead.7e90014","group":"1bdd63f2.633acc","name":"Data-table","order":3,"width":"24","height":"14","format":"<style>\n    th {\n        text-decoration: underline;\n    }\n    .numeric {\n        text-align: right;\n        padding-right: 15px;\n    }\n</style>\n\n<table cellpadding=\"1\" border=\"1\" id=\"table1\" class=\"table-hover\"  style=\"width: 100%;\">\n    <thead>\n        <tr>\n    <th>value1</th>        \n    <th>value2</th>\n    <th>value3</th>\n    <th>value4</th>\n    <th>value5</th>\n    <th>value7</th>\n    <th>value8</th>\n    <th>value9</th>\n    <th>value10</th>\n    <th>value11</th>\n    <th>value12</th>\n    <th>value13</th>\n    <th>value14</th>\n    <th>value15</th>\n    <th>save</th>\n        </tr>\n    </thead>\n    <tbody>\n        <tr ng-repeat=\"row in msg.payload\" ng-dblclick=\"sendRow(row)\">\n            <td class=\"numeric\" bgcolor=gray>{{row.value1}}</td>\n            <td contenteditable=\"true\">{{row.value2}}</td>\n            <td contenteditable=\"true\">{{row.value3}}</td>\n            <td contenteditable=\"true\">{{row.value4}}</td>\n            <td contenteditable=\"true\">{{row.value5}}</td>\n            <td bgcolor=gray>{{row.value7}}</td>\n            <td contenteditable=\"true\">{{row.value8}}</td>\n            <td bgcolor=gray>{{row.value9}}</td>\n            <td bgcolor=gray>{{row.value10}}</td>\n            <td contenteditable=\"true\">{{row.value11}}</td>\n            <td bgcolor=gray>{{row.value12}}</td>\n            <td bgcolor=gray>{{row.value13}}</td>\n            <td contenteditable=\"true\">{{row.value14}}</td>\n            <td contenteditable=\"true\">{{row.value15}}</td>\n             <td>\n\n    <md-button ng-click=\"sendRow(row)\">Set</md-button>\n        </tr>\n    </tbody>\n</table>\n\n<script>\n(function($scope) {\n    $scope.sendRow = function(obj) {\n       $scope.send({ \"payload\": obj });\n        $scope.send({ \"payload\": (document.getElementById(\"table1\").rows[1].innerHTML) });\n        };\n})(scope);\n</script>","storeOutMessages":false,"fwdInMessages":false,"templateScope":"local","x":565.0173492431641,"y":546.0104064941406,"wires":[["fc73bfc8.3103e"]]},{"id":"1bdd63f2.633acc","type":"ui_group","z":"","name":"Grafer","tab":"1cbf6c09.5ae5d4","order":1,"disp":true,"width":"32","collapse":false},{"id":"1cbf6c09.5ae5d4","type":"ui_tab","z":"","name":"Statistikk/Log","icon":"dashboard","order":1}]
I tried to paste your flow, but it had an error that wouldn’t allow it to be pasted.
I ended up going down this route from what I can see in your posting.
Have wrapped the flow in the previous post with ``` so it gets displayed properly and its quotes don’t get replaced with smart quotes - which breaks the JSON importing.
Nick,
Thanks for all your work on this. I actually went down this road almost exactly.
I actually built a very similar solution to your example a few days ago to create a table with rows that can be selected, and when selected push out a msg.payload. I’ve got a bunch of stuff in there for all the edge cases, but it works similarly to your example.
One difference was that I put the send on “tr”
<tr ng-repeat="option in msg.payload" ng-click="send({payload: option.value})">
Generally, this was spot on. I’ve posted a new question related to this same component where I need to cause this component to reload when new data comes into the UI Template
Thanks again.
Hi, did you actually get it to work so when you click the button it sends the edited value?
Karl
Here is another version im working on, however, now i cant even catch the injected values from mysql, let alone the edited values ;:slight_smile: this is really doing my head in.
Karl
[{"id":"767444a.f296fbc","type":"inject","z":"536107f9.eb5358","name":"Go","topic":"","payload":"1","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":"","x":290.0173645019531,"y":684.0104370117188,"wires":[["55f33c7c.c0eb34"]]},{"id":"55f33c7c.c0eb34","type":"function","z":"536107f9.eb5358","name":"dummyarray","func":"var myArray =[{ \"value1\": \"aaa\", \"value2\": \"A\", \"value3\": \"bbb\",\n\"value6\": \"B\", \"value4\": \"ccc\", \"value5\": \"C\", \"value7\": \"aaa\", \"value8\": \"A\",\n\"value9\": \"bbb\",\"value10\": \"B\", \"value11\": \"ccc\", \"value12\": \"C\"},{ \"value1\": \"aaa\", \"value2\": \"A\", \"value3\": \"bbb\",\n\"value6\": \"B\", \"value4\": \"ccc\", \"value5\": \"C\", \"value7\": \"aaa\", \"value8\": \"A\",\n\"value9\": \"bbb\",\"value10\": \"B\", \"value11\": \"ccc\", \"value12\": \"C\"},{ \"value1\": \"aaa\", \"value2\": \"A\", \"value3\": \"bbb\",\n\"value6\": \"B\", \"value4\": \"ccc\", \"value5\": \"C\", \"value7\": \"aaa\", \"value8\": \"A\",\n\"value9\": \"bbb\",\"value10\": \"B\", \"value11\": \"ccc\", \"value12\": \"C\"}];\nmsg.payload = myArray;\nreturn msg;","outputs":1,"noerr":0,"x":493.18408203125,"y":697.0104722976685,"wires":[["7933f1d5.93e56"]]},{"id":"7933f1d5.93e56","type":"ui_template","z":"536107f9.eb5358","group":"71c8d46f.362c8c","name":"Data-table","order":3,"width":"24","height":"14","format":"<style>\n th {\n text-decoration: underline;\n }\n .numeric {\n text-align: right;\n padding-right: 15px;\n }\n</style>\n\n\n<table cellpadding=\"1\" border=\"1\" id=\"table1\" class=\"table-hover\" style=\"width: 100%;\">\n <thead>\n <tr>\n <th>value1</th> \n <th>value2</th>\n <th>value3</th>\n <th>value4</th>\n <th>value5</th>\n <th>value7</th>\n <th>value8</th>\n <th>value9</th>\n <th>value10</th>\n <th>value11</th>\n <th>value12</th>\n <th>value13</th>\n <th>value14</th>\n <th>value15</th>\n <th>save</th>\n </tr>\n </thead>\n <tbody>\n <tr ng-repeat=\"row in msg.payload\" ng-dblclick=\"sendRow(row)\">\n <td class=\"numeric\" bgcolor=gray>{{row.value1}}</td>\n <td contenteditable=\"true\">{{row.value2}}</td>\n <td contenteditable=\"true\">{{row.value3}}</td>\n <td contenteditable=\"true\">{{row.value4}}</td>\n <td contenteditable=\"true\">{{row.value5}}</td>\n <td bgcolor=gray>{{row.value7}}</td>\n <td contenteditable=\"true\">{{row.value8}}</td>\n <td bgcolor=gray>{{row.value9}}</td>\n <td bgcolor=gray>{{row.value10}}</td>\n <td contenteditable=\"true\">{{row.value11}}</td>\n <td bgcolor=gray>{{row.value12}}</td>\n <td bgcolor=gray>{{row.value13}}</td>\n <td contenteditable=\"true\">{{row.value14}}</td>\n <td contenteditable=\"true\">{{row.value15}}</td>\n <td>\n\n <md-button ng-click=\"sendRow(row)\">Set</md-button>\n </tr>\n </tbody>\n</table>\n\n<script>\n(function($scope) {\n var array = [];\nvar table = document.querySelector(\"table tbody\");\nvar rows = table.children;\nfor (var i = 0; i < rows.length; i++) {\n\tvar fields = rows[i].children;\n var rowArray = [];\n for (var j = 0; j < fields.length; j++){\n rowArray.push(fields[j].innerHTML);\n }\n array.push(rowArray);\n} \n $scope.sendRow = function(obj) {\n$scope.send({ \"payload\": array });\n }; \n})(scope);\n</script>\n\n<!--script>\n(function($scope) {\n $scope.sendRow = function(obj) {\n $scope.send({ \"payload\": obj });\n $scope.send({ \"payload\": (document.getElementById(\"table1\").rows[1].innerHTML) });\n };\n})(scope);\n</script-->","storeOutMessages":false,"fwdInMessages":false,"templateScope":"local","x":700.0173568725586,"y":701.0104732513428,"wires":[["3cadbc3.fed4144"]]},{"id":"3cadbc3.fed4144","type":"debug","z":"536107f9.eb5358","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":929.0173416137695,"y":696.0104455947876,"wires":[]},{"id":"71c8d46f.362c8c","type":"ui_group","z":"","name":"Group 1","tab":"d8af7578.1019a8","order":1,"disp":true,"width":"32","collapse":false},{"id":"d8af7578.1019a8","type":"ui_tab","name":"Tab 6","icon":"dashboard","order":1}]
