Post Form data from function including array
Hi
I am trying to use an API and POST multipart/form-data. I am using the example from the API docs which includes an array. When I try to post this the error is Arrays are not supported. I am using a function block to pass in the data.
The function code is
msg.payload = { "customer_id": 153618000000549022,"invoice_number": "INV-00003","date": "2019-06-19", "line_items": [ {"item_id": 982000000030049,"name": "Hard Drive","item_order": 1}] };
msg.headers = {'content-type':'multipart/form-data'};
Any suggestions appreciated
Which API docs are you referring to?
The form data library we use does not support array types. Are you sure you want to be using multipart/form-data and not application/x-www-form-urlencoded?
Hi Nick
Thanks for the reply. The API docs are here and I am trying to Create and Invoice.
https://www.zoho.com/invoice/api/v3/#Invoices_Create_an_invoice
I have contacted support and they have responded as follows
If you look at the POST call you're making to create invoice, you are passing the JSONString as a query parameter. Instead of that, you need to pass it as form-data.
Thanks for the help
Hi Nick
Thanks for the help
You appear to have repeated your post. Please don’t
Their docs show they expect the form-data to have a single property called JSONString with its value being the JSON encoded object.
That suggests the following would work:
var data = { "customer_id": 153618000000549022,"invoice_number": "INV-00003","date": "2019-06-19", "line_items": [ {"item_id": 982000000030049,"name": "Hard Drive","item_order": 1}] };
msg.headers = {
msg.payload = {
    JSONString: JSON.stringify(data)
Apologies, I just noticed that I should have replied to Nicks advice
Thanks Nick, That worked I only had to change the numbers to strings
You can edit posts... No need to repost content just to tag someone in.
