Hello
I have an API offered my my pool manufacturer that I am able to use to communicate with my pool controller.
The API use is shown below.
Do I just use an inject node, then set the payload to pool_api_code: ABCDEF, through to a http node which will return the response JSON?
Note: ABCDEF is provided by the pool supplier.
Apologies for asking a dumb question, but I cannot test this out without forking out alot of money for the controller itself. I don't want to fork out the money until I have complete confidence this will work with node red.
URL: /api/poolconfig
Required JSON POST object:
pool_api_code: string
Successful Response JSON object:
pool_spa_selection_enabled: boolean,
heat_cool_selection_enabled: boolean,
has_heaters: boolean,
has_solar_systems: boolean,
has_channels: boolean,
has_valves: boolean,
has_lighting_zones: boolean,
has_favourites: boolean,
heaters: [
heater_ number: integer
solar_systems: [
solar _number: integer
channels: [
channel_ number: integer,
function: integer,
valves: [
valve_number: integer,
function: integer,
lighting_zones: [
lighting_zone_number: integer,
color_enabled: boolean,
colors_available: [
color_number: integer,
color_name: string
favourites: [
favourite_number: integer,
