Node red newby - change node - to string with payload parameter
I am new to node red (Raspberry Pi, Node Red v1.3.5), have already read many docs. However, I can't find an answer to my current problem, which I'm sure is very trivial..
I want to query the status of a device (3d printer snapmaker) via http requests. To do this, I first need to get a token via an http request POST from the device. This works. This token must then be specified as a parameter in an http GET. Here I fail.
I have so far
The answer is for example the following
{"token":"c1f2751a-52de-4f5f-a147-909c8ff98ff4","readonly":false,"series":"Snapmaker 2.0 A350","headType":1,"hasEnclosure":true}
Now I add a http request GET. This must call the following URL http://192.168.178.163:8080/api/v1/status?token=[token]
For this I have set up a http request like this:
But {{...}} is obviously not correct. I also tried it with three { with unfortunately the same result.
Unfortunately I do not get further here now.
Who can help me. Many thanks and sorry for this beginner question ....
Regards
Sepp
as far as I can tell, the token is in payload.token not payload.token.value
i.e. use http://192.168.178.163:8080/api/v1/status?token={{payload.token}}
the best way to ensure accuracy when entering the path to a property is to use the features provided (copy path)...
There’s a great page in the docs that will explain how to use the debug panel to find the right path to any data item.
BX00Cy7yHi
https://nodered.org/docs/user-guide/messages
