Pre-populating ui_form
In the D2 docs here Form ui-form | Node-RED Dashboard 2.0, an example is given on how to pre-populate a ui-form. Has this actually been implemented? No matter what I have tried I cannot get a form to populate with the given example.
Cheers
Bob
I can get form to prepopulate using latest 1.12.4, there a few issues though.
  • When prepopulated you have to click on all fields before submit button works
  • the prepopulation object is passed through the node without a submit, which seems a bad idea.
example flow
[{"id":"0872583c36c11d85","type":"inject","z":"d1395164b4eec73e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"name\":\"aaa\",\"phone\":\"1234\"}","payloadType":"json","x":110,"y":200,"wires":[["4e2122c1d3d77fd9"]]},{"id":"4e2122c1d3d77fd9","type":"ui-form","z":"d1395164b4eec73e","name":"","group":"9d83cd8b3d5ee33c","label":"","order":1,"width":0,"height":0,"options":[{"label":"Name","key":"name","type":"text","required":true,"rows":null},{"label":"Phone","key":"phone","type":"number","required":true,"rows":null}],"formValue":{"name":"","phone":""},"payload":"","submit":"submit","cancel":"clear","resetOnSubmit":true,"topic":"topic","topicType":"msg","splitLayout":"","className":"","x":310,"y":160,"wires":[["c6708522f7441ae1"]]},{"id":"c6708522f7441ae1","type":"debug","z":"d1395164b4eec73e","name":"debug 2561","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":470,"y":160,"wires":[]},{"id":"9d83cd8b3d5ee33c","type":"ui-group","name":"Group1","page":"c694d0ebe0d2b702","width":"6","height":"1","order":1,"showTitle":true,"className":"","visible":"true","disabled":"false"},{"id":"c694d0ebe0d2b702","type":"ui-page","name":"Page1","ui":"1805777f90e92057","path":"/page1","icon":"home","layout":"grid","theme":"a965ccfef139317a","order":2,"className":"","visible":"true","disabled":"false"},{"id":"1805777f90e92057","type":"ui-base","name":"dashboard","path":"/dashboard","includeClientData":true,"acceptsClientConfig":["ui-notification","ui-control"],"showPathInSidebar":false},{"id":"a965ccfef139317a","type":"ui-theme","name":"HN Theme","colors":{"surface":"#5c5c5c","primary":"#00fdff","bgPage":"#383838","groupBg":"#4f4f4f","groupOutline":"#858585"},"sizes":{"pagePadding":"12px","groupGap":"12px","groupBorderRadius":"4px","widgetGap":"12px"}}]
I have raised an issue on above ui-form passing prepopulated and submit not clickable Ā· Issue #1069 Ā· FlowFuse/node-red-dashboard Ā· GitHub
Thanks for raising, will address when back at work on Tueday
This was implemented in 1.12.4 which only came out this week
