Preset Configuration Nodes?
Is there a way to preset configuration nodes for node-red?
I'm looking to set up a dev environment that has preset configuration nodes so its easy to pick configuration presents for different nodes.
For example, the node-red-contrib-sqldbs node (allows connection to databases). I would like to create preset config nodes for these so that other dev's you can easily pick different connections on start up, without having to initially define them themselves.
Is there anyway to do this? If not is there any good workarounds?
