Problem authentication
I have configured my Nodered with login/password
The first time i connect , Nodered ask me Login/Password , it is ok
But for the next connection it ask nothing and connect directly
Thanks for your help
gdero
Hi @gdero - Welcome to the forums.
Is this with the same browser?
if so, it is entirely normal, logins have an expiry (I cant remember the default time).
but if you want to kill the logon session - you need to logout (top right), or wait until it expires
This can be configured in the settings file
sessionExpiryTime: 604800, // in secs, default 7d=604800
Thats it!
I knew it was there, but couldn't remember the default value!
Thank you for your answer
However ,I have no parameter "sessionExpiryTime " in my setting.js ; i have tried to add it at the end of my file but i get an error when launching nodered !!!!
The settings file is a Javascript file so you have to add sections using JS syntax.
If you what help adding it, an example of where and how you added it would be required to see where you went wrong.
This topic may help you
Hi @gdero,
You will add this in the same place you added the auth details.
adminAuth: {
   type: "credentials",
   sessionExpiryTime: 86400, /* Here */
   users: [{
Don't forget to restart Node RED
All info here:
https://nodered.org/docs/user-guide/runtime/securing-node-red
Thank you for your help
thank you for your help .
