I have problem in converting decimal to ascii. Can anyone glad to help me.?
In a function node you may convert it by javascript:
https://www.codegrepper.com/code-examples/javascript/convert+number+to+ascii+javascript
You can also use JSONATA in a change node. Set msg.payload to a JSONATA expression
the $string() expression works well for this;
https://try.jsonata.org/8L0S61x9m
This description is ambiguous. I can think of at least two interpretations, and you have gotten an answer to each. Please mark one as the solution, or clarify your issue.
