Ascii to Decimal
Does anyone have a function that converts an ascii string to decimal (string)?
So if pass “ABCD1” into the function the output would be “65” “66” “67” “68” “49”
Use a function node.
const stringToConvert = msg.payload;
msg.payload = getCharCodes(stringToConvert).join(" ");
function getCharCodes(s){
    let charCodeArr = [];
    for(let i = 0; i < s.length; i++){
        let code = s.charCodeAt(i);
        charCodeArr.push(code);
    return charCodeArr;
Proof...
Do you really want a string of quotes and numbers? or did you want an array of strings???
Legend this is exactly what I needed!!! Much appreciated!
or take advantage of nodejs Buffer
msg.payload = Buffer.from(msg.payload, 'ascii').join(" ")
