Hey Experts,
I hope to  find some helps here.
At first I convert INT to CHAR --> Easy, take a look:
// Split the string into array of individual values
var parts = msg.payload.split(" ");
// Remove the last blank part caused by the trailing comma
parts.pop();
// Parse each part of the string to a number
var bytes = parts.map(v => parseInt(v))
// Create a new Buffer from those bytes and convert back to String
msg.payload = Buffer.from(bytes).toString();
It works... But now I like to do same in other direction... Hmmm
Example:
WLC0270 --> 87 76 67 48 50 55 48 ??
I testing something but nothings works,
at first I create an array for each character:
var parts = msg.payload.split("");
then me is missing a rule to convert from(string).tobyte();
So you see currently I´am not an expert yet.
Hope anybody understand my issue.
Thanks in advance.
BG
