I installed the Node.js and then when I typed the command npm install node-mcp23017 --save it return to me the following error:
i2c.target.mk:99: recipe for target 'Release/obj.target/i2c/src/i2c.o' failed
make: *** [Release/obj.target/i2c/src/i2c.o] Error 1
make: Leaving directory '/home/pi/node_modules/i2c/build'
gyp ERR! build error
gyp ERR! stack Error: make failed with exit code: 2
gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
gyp ERR! stack at ChildProcess.emit (events.js:193:13)
gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:255:12)
gyp ERR! System Linux 4.19.32-v7+
gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
gyp ERR! cwd /home/pi/node_modules/i2c
gyp ERR! node -v v11.13.0
gyp ERR! node-gyp -v v3.8.0
gyp ERR! not ok
npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
npm WARN pi No description
npm WARN pi No repository field.
npm WARN pi No README data
npm WARN pi No license field.
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! i2c@0.2.3 install: node-gyp rebuild
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the i2c@0.2.3 install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! /home/pi/.npm/_logs/2019-04-07T11_00_04_905Z-debug.log
I get this error for any kind on intallation for the I2C modules.
Instead if I use the terminal to see the devices connected I can see them easily typing i2cdetect -y 1.
I can't understand how to solve this problem to install this palette.
Unfortunately didn't change anything and still get this error below. I installed at the beginning Node-Red with the script provided on the node-red website and then just made apt-get update and apt-get upgrade
Should I chaange something? I'm using NPM directly into the folder node-red but I can't make it work.
make: Leaving directory '/home/pi/.node-red/node_modules/i2c/build'
gyp ERR! stack at ChildProcess.emit (events.js:189:13)
gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
gyp ERR! cwd /home/pi/.node-red/node_modules/i2c
gyp ERR! node -v v10.15.3
gyp ERR! not ok
npm WARN node-red-project@0.0.1 No repository field.
npm WARN node-red-project@0.0.1 No license field.
npm ERR! errno 1
npm ERR!
npm ERR! /home/pi/.npm/_logs/2019-04-07T12_40_14_264Z-debug.log
@Colin I'm running a Raspbian Stretch Lite on my Pi
I already had a look mostly around internet but couldn't find anything that helped me out to solve this problem.
