Problem to replace a JSON object in Array
Hi , I have a question which might be more related to JS than Node Red.....
I'm trying to replace a JSON object in a Array but can't get it work. Each time the new data replaced in the array is a string, but not an object. I tried different ways, but no luck.
However, when I set the same object to a new object in the same array, then it works perfectly....
Here is a snippest of the code I use to manipulate data before sending it back into the array :
var csv = global.get("csvContent");
// When device name info provided from DB :
if (msg.topic == "DB_Device_Name" && flow.get("DeviceType") != "Not Set !") {
    for (let i = 0; i < csv.length; i++) {
        // Build final end point name :
        var descriptorDesc = csv[i].descriptor.desc;
        var descriptorLabel = csv[i].descriptor.label; //>> {desc:,label:01C01-VGW1_CH07_RxA04}
        node.warn("descriptorLabel " + descriptorLabel)
        descriptorLabel = msg.payload + "_CH0" + csv[i].chNumber + csv[i].rxTx + csv[i].vertexType + csv[i].audCh;
       let newDesc = {"desc" : descriptorDesc}
       let newLabel = {"label" : descriptorLabel}
        csv[i].descriptor = Object.assign({}, newDesc, newLabel )
        csv[i].test = Object.assign({}, newDesc, newLabel )
global.set("csvContent", csv);
When I want to replace descriptor here is the result ( I also put some screenshots, as the code section does not show any difference) :
{"desc":"","label":"12345_CH07_RxA04"}
when I set it to csv[i].test :
If useful, here is also a copy of one of the objects from csvContent source ( and dest) global variable :
{"#":"device73.484735f6-a1ea-596e-8282-0cd1108e6be2.R01a52f67-554c-5791-8503-fcbee07f93d9","active":"true","bidirPartnerId":"null","codecFormat":"Audio","configPriority":"off","control":"off","custom":"{}","descriptor":"{\"desc\":\"\",\"label\":\"12345_CH07_RxA04\"}","extraAlertFilters":"[]","Factory label":"receiver_s06_a03","isIgmpSource":"false","mainDstIp":"null","mainDstMac":"null","mainDstPort":"null","mainDstVlan":"null","mainSrcGateway":"null","mainSrcIp":"null","mainSrcMac":"null","mainSrcNetmask":"null","public":"false","sdpSupport":"true","sipsMode":"NONE","spareDstIp":"null","spareDstMac":"null","spareDstPort":"null","spareDstVlan":"null","spareSrcGateway":"null","spareSrcIp":"null","spareSrcMac":"null","spareSrcNetmask":"null","tags":"[]","useAsEndpoint":"false","chNumber":7,"vertexType":"A","rxTx":"_Rx","audCh":"04","test":{"desc":"","label":"12345_CH07_RxA04"}}
Thanks to you in advance for your tips !
Not certain why that would be happening without adding some debugging etc. However, I'd likely side step the issue and simply assign a new object explicitly:
        csv[i].descriptor = {
           "desc" : descriptorDesc,
Note, you may have something affecting the context data by reference in another part of your flow (that's my disclaimer)
In CsvContent the property descriptor is a string, so you can not assign a object property to a string. Unless as in @Steve-Mcl suggestion you assign descriptor as an object.
Mmm sorry I sent a copy of the CSV after it was modified by the non-working script...
I can definitely say it's an object at start, otherwise the script would not even be able to build the csv[i].test object....
I think I checked already the other nodes in the flow, but @Steve-Mcl might be right, there might something which also brings modification to the problematic obj in the array.... I can't see any other reason right now.
Hi, I found where my problem comes from, but still can't explain it.
Downstream in the flow after setting up the descriptor value as an object, I have a node which stringify it, only to be displayed correctly in a table :
The code of this second node is :
// Manage datas for proper display in table :
        csv[i].descriptor = JSON.stringify(csv[i].descriptor);
msg.payload = "setdata"
msg.data = csv;
As you can see the output of this node right now is not connected anywhere, and I don't make use of global.set() to write back the array..... but the global stored array is being modified.
As soon as I remove the link to this node, everything is fine :
am I missing something obvious ?
Object are stored in one memory slot, and are passed by reference.
So csv = global.get("csvContent") Tell js to reference the same memory. When you change csv the global is changed to as they reference the same memory
try
csv = RED.util.cloneMessage(global.get("csvContent"))
https://nodered.org/docs/api/modules/v/0.20.0/@node-red_util_util.html#.cloneMessage
ok thank you, it works.
I'll need to have a serious look on all this. My (wrong) guess was that a variable stored in any context could not be modified until we use any kind of context.set() to write it back....
For primitive types, that would be correct.
  • strings
  • integers
  • booleans
  • etc etc
But for complex types
  • Arrays
  • Objects
  • classes
  • etc etc
They are pass-by-ref
It's not Node RED behaving this way, more how javascript works
EDIT
Oh - just seen the link provided by @E1cid that explains.
