Problem to use node-red-contrib-telegrambot
I am using the node-red-contrib-telegrambot to send messages and receive answers from my bot, but so far I do not get anything back.
  1. I think I properly set up my bot and I have received my API token
  2. I set up my Bot in the config nodes without any issue, it seems, I see the "connected" status
  3. I send a payload to the node-sender:
    {"chatId":1130402123,"type":"message","content":"hello from node-red!"}
    (I modified the chatID, but this is my personal user id received from IoTwithus.com bot)
I receive nothing back in telegram, nor I get any output from the node-sender
Any help would be appreciated...
Hi. It is a good idea to start with the built in examples. (they do work)
ctrl+I
Try them out & follow the instructions in the readme
Thanks Steve. Indeed all examples work. I tested on another of my node-red instances.
I think I had something wrong on my first node-red instance, maybe an old version. I will continue using this one to explore Telegram bot possibilities, as it works like a charm...
By the way, thanks a lot for showing how we can easily use node-red samples directly from the dashboard by using CTRL+I ! This is a great feature...
