Hi! I would appreciate if someone could help me with a problem with call service nodes that don't behave as expected.
I have a device with two digital output channels connected to my Home Assistant. Each channel has its own entity in Home Assistant and can also be controlled individually from HA dashboard or by an automation rule, but when trying to control the entities from the node-red call service node, this doesn't work, instead when one of the turn_on or turn_off services is activated for one of the entities, the intended entity gets impacted as expected but also the other entity is impacted for the same device.
Does anyone know how to fix this?
