Problem with connect sim module to raspberry pi
i had try to connect module sim900a mini v3.8.2 to raspberry pi zero w v1.1
this is what i did ********
  1. Start raspi-config: sudo raspi-config.
  2. Select option 3 - Interface Options.
  3. Select option P6 - Serial Port.
  4. At the prompt Would you like a login shell to be accessible over serial? answer 'No'
  5. At the prompt Would you like the serial port hardware to be enabled? answer 'Yes
and in /boot/config.txt ***********
dtoverlay=pi3-disable-bt
dtparam=spi=on
dtparam=i2c_arm=on
#dtoverlay=w1-gpio
enable_uart=1
core_freq=250
and i set in /boot/cmdline.txt ************
console=tty1 root=PARTUUID=36517a7a-02 rootfstype=ext4 fsck.repair=yes rootwait modules-load=dwc2,g_ether quiet splash plymouth.ignore-serial-consoles earlycon=pl011,mmio32,0x20201000 core_freq=250
also try to set console=tty1 root=PARTUUID=36517a7a-02 rootfstype=ext4 fsck.repair=yes rootwait modules-load=dwc2,g_ether quiet splash plymouth.ignore-serial-consoles
so in node red i use serialport /dev/ttyS0 baud rate 9600 data bits 8 parity none stop bits 1
so is there any thing i did wrong ? please ?
note : i alredy test the sim900a with arduino and it work
This is doesn't appear to be a Node-RED related problem.
The hardware interface is between an RPi and the SIM900a GSMmodule, you might be better to look either in RPi forums, or somewhere that supports the SIM900a GPRS module. The first hit for SIM900 on Google came up with a link to the Instructables site.
