Hello guys, hope you doing well. I have a rare situaction on handling arrays, hope you can help me. The issue itself is that am using two arrays, one main and another to store certain amount of data from the fisrt one like a stack, wich runs all along the first array.length.
as far as i understand the variable aux should be pieces of length 5 from the variable l1ca, something like [l1ca[0],..l1ca[4] and then [l1ca[1],...l1ca[5], and so on, but instead am seeing just the last five elements of the main array placed at all over aux variable. am i doing something wrong?.
by the way, am using windows 11 with node v14.15.14 & npm 6.4.10
hope i make myselft explaind and thanks for read!.
[{"id":"934fa1582dce094b","type":"function","z":"e768492ea5ee7729","name":"function 1","func":"var arr_pool = [];\nvar time = [1, 2, 3, 4, 5, 6, 7, 8, 9, 10];\nvar l1ca = [46.1, 45.2, 46.6, 47.2, 43.1, 49.3, 52.2, 52.2, 49.1, 50.3];\n\nvar aux = [];\nvar arr_val = [];\n\nfor (let a = 0; a < time.length; a++) {\n var value = l1ca[a];\n arr_pool.push(value);\n arr_val.push(value);\n\n if (arr_pool.length > 5) {\n aux.push(arr_pool);\n arr_pool.shift();\n }\n}\n\nmsg.payload = [arr_val,arr_pool, aux.length];\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":440,"y":240,"wires":[["978af7dce0fab775"]]},{"id":"82d72ca23e5f9bfd","type":"inject","z":"e768492ea5ee7729","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":260,"y":240,"wires":[["934fa1582dce094b"]]},{"id":"978af7dce0fab775","type":"debug","z":"e768492ea5ee7729","name":"debug 5","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":620,"y":240,"wires":[]}]
