I try to use a Siemens MPI USB adapter but when installing node-red-contrib-mpi-s7 MODULE_NOT_FOUND appears, it does not let me configure the MPI adapter, installing from the terminal does let me access the MPI endpoint configuration but does not find the adapter, searching I tried to install the dependency manually @protocols/mpi-s7 but it does not find it in the NPM repository, what can I do?
