"Function tried to send a message of type string"
var dir1 ="D SkylineDynamics ";
var dir2 =msg.payload.output.text[0];
var joined = dir1 + dir2;
return joined;
Wire that into a debug node and check what the msg.payload now contains
because you are trying to return a string joined
The twitter node and the rest of Node-RED expects to receive an object.
As part of that object the bit that the twitter node knows what to do is msg.payload
so as @knolleary showed you
msg.payload = "D @NodeRED Hello";
yah but it work but did not send the dialogue is send just hello
So i tried to do what you said is Concatenating strings but did not work
msg.payload =msg.payload.output.text[0];
msg.payload ="D SkylineDynamics ";
can i use it with out return ?
Hi @Malhakbani
At this point, take a step back and go learn some basic JavaScript
Your last example code:
First sets payload to the value of msg.payload.output.text[0].
Then it sets payload to the text "D SkylineDynamics " - overwriting what you had just set it to.
You need to join the value of msg.payload.output.text[0] to the end of the string "D SkylineDynamics ". We've given you links to pages that explain how to join strings.
i know javascript but i just sent it as JOKE ,
i tried to join the value of them :
return joined;
i apologize if i asked to much questions but i'am tried to learn
Just please help me with final thing
thank you @knolleary @ukmoose @dceejay
w
Sorry, I must have missed that.
return joined;
This is returning a string. You cannot do that. Youve already seen the error that causes.
It has been explained you should update msg.payload and then return msg.
guys guys thank you so much much love it works
msg.payload ="D username "+msg.payload.output.text[0];
i looooooove you guys
but know i don't know how to make it global for all user how contact me
As you
know javascript
I'm are you can work out from the msg object you receive where the senders username is and then modify the output object to include it
var one = " D" ;
var two = "SkylineDynamics";
var joined = one + two;
msg.payload =" joined "+ msg.payload.output.text[0];
msg.account_id = msg.req.account_id;
var name = msg.account_id;
msg.payload ="D name "+msg.payload.output.text[0];
i tried every solution did not work
i know the problem is it have to be formatted like this ( "D username" ) and quotes is very important
but the problem how to get the user name = msg.account_id or there is another name for the account id for example msg.username_id . and how to join them to gather .
var name = "D"
var user = " username"
var test = `""${name+user}""`
msg.payload =test + msg.payload.output.text[0];
msg.payload.account= "D"
msg.payload.user = " username"
msg.payload.join = `"${msg.payload.account+msg.payload.user }"`
msg.payload =msg.payload.join+msg.payload.output.text[0];
@Malhakbani do you have a question to go with any of these code excerpts you are sharing?
all of this did not work
that is why i'am sharing it
please help
