Hi i have the following Template:
it works fine but if i switch to another tab and switch back (all with ui control) the template is empty.
Any Idea ?
Thank you
oh i forgot: if i reload the hole page (Browser F5) the template is visible again.
Read this thread - same issue I beleive. It has answers.
Hi.
No sorry. i have tested every possible config.
i've using the template in similar way on another tab and there i don't have the "Problem".
greets
Can you try with the check box "Pass trough message from input" disabled?
no change.
Note: i'am running on v0.20.7 on an raspberry. today i will try to backup an make an update to version v1.0.6
