Probleme of installing the tensorflow node
hi, i have a node version 16.16.0 and NPM 9.7.3 ,i tried to install the tensorflow node i get this by installing it directly from palette
2023-06-11T14:34:44.373Z Install : node-red-contrib-tensorflow 0.4.2  2023-06-11T14:34:44.384Z npm.cmd install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict node-red-contrib-tensorflow@0.4.2  ----------------------------------------------------------- 2023-06-11T14:34:54.929Z Install : node-red-contrib-tensorflow-js 0.0.8  2023-06-11T14:34:56.035Z [err] npm 2023-06-11T14:34:56.036Z [err]   2023-06-11T14:34:56.038Z [err] WARN config global `--global`, `--local` are deprecated. Use `--location=global` instead. 2023-06-11T14:35:00.160Z [err] npm 2023-06-11T14:35:00.162Z [err]  WARN 2023-06-11T14:35:00.162Z [err]  config production Use `--omit=dev` instead. 2023-06-11T14:37:40.356Z [err] npm 2023-06-11T14:37:40.357Z [err]  WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142 2023-06-11T14:37:40.439Z [err] npm  2023-06-11T14:37:40.439Z [err] WARN deprecated har-validator@5.1.5: this library is no longer supported 2023-06-11T14:37:42.050Z [err] npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details. 2023-06-11T14:37:42.098Z [err] npm  2023-06-11T14:37:42.098Z [err] WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
and this on cmd
npm WARN config global `--global`, `--local` are deprecated. Use `--location=global` instead.
npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
npm ERR! code 1
npm ERR! path C:\Users\PC\node_modules\@tensorflow\tfjs-node
npm ERR! command failed
npm ERR! command C:\WINDOWS\system32\cmd.exe /d /s /c node scripts/install.js
npm ERR! CPU-windows-4.1.0.zip
npm ERR! https://storage.googleapis.com/tensorflow/libtensorflow/libtensorflow-cpu-windows-x86_64-2.9.1.zip
npm ERR! node-pre-gyp install failed with error: Error: Command failed: node-pre-gyp install --fallback-to-build
npm ERR! node-pre-gyp info it worked if it ends with ok
npm ERR! node-pre-gyp info using node-pre-gyp@1.0.9
npm ERR! node-pre-gyp info using node@16.16.0 | win32 | x64
npm ERR! node-pre-gyp info check checked for "C:\Users\PC\node_modules\@tensorflow\tfjs-node\lib\napi-v8\tfjs_binding.node" (not found)
npm ERR! node-pre-gyp http GET https://storage.googleapis.com/tf-builds/pre-built-binary/napi-v8/4.1.0/CPU-windows-4.1.0.zip
npm ERR! node-pre-gyp ERR! install response status 404 Not Found on https://storage.googleapis.com/tf-builds/pre-built-binary/napi-v8/4.1.0/CPU-windows-4.1.0.zip
npm ERR! node-pre-gyp WARN Pre-built binaries not installable for @tensorflow/tfjs-node@4.1.0 and node@16.16.0 (node-v93 ABI, unknown) (falling back to source compile with node-gyp)
npm ERR! node-pre-gyp WARN Hit error response status 404 Not Found on https://storage.googleapis.com/tf-builds/pre-built-binary/napi-v8/4.1.0/CPU-windows-4.1.0.zip
npm ERR! gyp info it worked if it ends with ok
npm ERR! gyp info using node-gyp@9.3.1
npm ERR! gyp info using node@16.16.0 | win32 | x64
npm ERR! gyp info ok
npm ERR! gyp info find Python using Python version 3.8.0 found at "C:\Users\PC\AppData\Local\Programs\Python\Python38\python.exe"
npm ERR! gyp http GET https://nodejs.org/download/release/v16.16.0/node-v16.16.0-headers.tar.gz
npm ERR! gyp http 200 https://nodejs.org/download/release/v16.16.0/node-v16.16.0-headers.tar.gz
npm ERR! gyp http GET https://nodejs.org/download/release/v16.16.0/SHASUMS256.txt
npm ERR! gyp http GET https://nodejs.org/download/release/v16.16.0/win-x86/node.lib
npm ERR! gyp http GET https://nodejs.org/download/release/v16.16.0/win-arm64/node.lib
npm ERR! gyp http GET https://nodejs.org/download/release/v16.16.0/win-x64/node.lib
npm ERR! gyp http 200 https://nodejs.org/download/release/v16.16.0/SHASUMS256.txt
npm ERR! gyp http 200 https://nodejs.org/download/release/v16.16.0/win-x86/node.lib
npm ERR! gyp http 200 https://nodejs.org/download/release/v16.16.0/win-x64/node.lib
npm ERR! gyp http 404 https://nodejs.org/download/release/v16.16.0/win-arm64/node.lib
npm ERR! gyp ERR! find VS
npm ERR! gyp ERR! find VS msvs_version not set from command line or npm config
npm ERR! gyp ERR! find VS VCINSTALLDIR not set, not running in VS Command Prompt
npm ERR! gyp ERR! find VS could not use PowerShell to find Visual Studio 2017 or newer, try re-running with '--loglevel silly' for more details
npm ERR! gyp ERR! find VS looking for Visual Studio 2015
npm ERR! gyp ERR! find VS - not found
npm ERR! gyp ERR! find VS not looking for VS2013 as it is only supported up to Node.js 8
npm ERR! gyp ERR! find VS **************************************************************
npm ERR! gyp ERR! find VS You need to install the latest version of Visual Studio
npm ERR! gyp ERR! find VS including the "Desktop development with C++" workload.
npm ERR! gyp ERR! find VS For more information consult the documentation at:
npm ERR! gyp ERR! find VS https://github.com/nodejs/node-gyp#on-windows
npm ERR! gyp ERR! configure error
npm ERR! gyp ERR! stack Error: Could not find any Visual Studio installation to use
npm ERR! gyp ERR! stack     at VisualStudioFinder.fail (C:\Users\PC\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:122:47)
npm ERR! gyp ERR! stack     at C:\Users\PC\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:75:16
npm ERR! gyp ERR! stack     at VisualStudioFinder.findVisualStudio2013 (C:\Users\PC\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:369:14)
npm ERR! gyp ERR! stack     at C:\Users\PC\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:71:14
npm ERR! gyp ERR! stack     at C:\Users\PC\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:390:16
npm ERR! gyp ERR! stack     at C:\Users\PC\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\lib\util.js:54:7
npm ERR! gyp ERR! stack     at C:\Users\PC\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\lib\util.js:33:16
npm ERR! gyp ERR! stack     at ChildProcess.exithandler (node:child_process:406:5)
npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:527:28)
npm ERR! gyp ERR! stack     at maybeClose (node:internal/child_process:1092:16)
npm ERR! gyp ERR! stack     at Process.ChildProcess._handle.onexit (node:internal/child_process:302:5)
npm ERR! gyp ERR! System Windows_NT 10.0.19045
npm ERR! gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Users\\PC\\AppData\\Roaming\\npm\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "configure" "--fallback-to-build" "--module=C:\\Users\\PC\\node_modules\\@tensorflow\\tfjs-node\\lib\\napi-v8\\tfjs_binding.node" "--module_name=tfjs_binding" "--module_path=C:\\Users\\PC\\node_modules\\@tensorflow\\tfjs-node\\lib\\napi-v8" "--napi_version=8" "--node_abi_napi=napi" "--napi_build_version=8" "--node_napi_label=napi-v8"
npm ERR! gyp ERR! cwd C:\Users\PC\node_modules\@tensorflow\tfjs-node
npm ERR! gyp ERR! node -v v16.16.0
npm ERR! gyp ERR! node-gyp -v v9.3.1
npm ERR! gyp ERR! not ok
npm ERR! node-pre-gyp ERR! build error
npm ERR! node-pre-gyp ERR! stack Error: Failed to execute 'C:\Program Files\nodejs\node.exe C:\Users\PC\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js configure --fallback-to-build --module=C:\Users\PC\node_modules\@tensorflow\tfjs-node\lib\napi-v8\tfjs_binding.node --module_name=tfjs_binding --module_path=C:\Users\PC\node_modules\@tensorflow\tfjs-node\lib\napi-v8 --napi_version=8 --node_abi_napi=napi --napi_build_version=8 --node_napi_label=napi-v8' (1)
npm ERR! node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (C:\Users\PC\node_modules\@mapbox\node-pre-gyp\lib\util\compile.js:89:23)
npm ERR! node-pre-gyp ERR! stack     at ChildProcess.emit (node:events:527:28)
npm ERR! node-pre-gyp ERR! stack     at maybeClose (node:internal/child_process:1092:16)
npm ERR! node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (node:internal/child_process:302:5)
npm ERR! node-pre-gyp ERR! System Windows_NT 10.0.19045
npm ERR! node-pre-gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Users\\PC\\node_modules\\@mapbox\\node-pre-gyp\\bin\\node-pre-gyp" "install" "--fallback-to-build"
npm ERR! node-pre-gyp ERR! cwd C:\Users\PC\node_modules\@tensorflow\tfjs-node
npm ERR! node-pre-gyp ERR! node -v v16.16.0
npm ERR! node-pre-gyp ERR! node-pre-gyp -v v1.0.9
npm ERR! node-pre-gyp ERR! not ok
npm ERR! * Downloading libtensorflow
npm ERR!
npm ERR! * Building TensorFlow Node.js bindings
npm ERR! A complete log of this run can be found in: C:\Users\PC\AppData\Local\npm-cache\_logs\2023-06-11T15_24_04_838Z-debug-0.log
You have the information in the error log (Visual Studio is missing...)
Did you tick the box to install necessary tools
Some nodes have a compile step and you need the necessary tools installed in order to compile it. You could of course install visual studio. However, it is not necessary (and is overkill) as you can simply include all of the necessary build tools when you install node js
