Unable to install @tensorflow/tfjs-node
Hi, I am a beginner to node-red. I have been trying to install the @tensorflow/tfjs-node to node-red. In Winodws cmd and node-red on IBM cloud.
Here is the cmd result:
C:\<<path>>\.node-red>npm install @tensorflow/tfjs-node
npm WARN ERESOLVE overriding peer dependency
npm WARN While resolving: node-red-project@0.0.1
npm WARN Found: @tensorflow/tfjs-node@1.7.4
npm WARN node_modules/@tensorflow/tfjs-node
npm WARN   peer @tensorflow/tfjs-node@"^1.4.0" from node-red-contrib-tf-model@0.1.11
npm WARN   node_modules/node-red-contrib-tf-model
npm WARN     node-red-contrib-tf-model@"^0.1.11" from the root project
npm WARN   1 more (the root project)
npm WARN
npm WARN Could not resolve dependency:
npm ERR! code 1
npm ERR! path C:\<path>\.node-red\node_modules\@tensorflow\tfjs-node
npm ERR! command failed
npm ERR! command C:\WINDOWS\system32\cmd.exe /d /s /c node scripts/install.js
npm ERR! CPU-windows-3.20.0.zip
npm ERR! https://storage.googleapis.com/tensorflow/libtensorflow/libtensorflow-cpu-windows-x86_64-2.7.3.zip
npm ERR! node-pre-gyp install failed with error: Error: Command failed: node-pre-gyp install --fallback-to-build
npm ERR! node-pre-gyp info it worked if it ends with ok
npm ERR! node-pre-gyp info using node-pre-gyp@1.0.9
npm ERR! node-pre-gyp info using node@16.17.0 | win32 | x64
npm ERR! node-pre-gyp info check checked for "C:\<path>\.node-red\node_modules\@tensorflow\tfjs-node\lib\napi-v8\tfjs_binding.node" (not found)
npm ERR! node-pre-gyp http GET https://storage.googleapis.com/tf-builds/pre-built-binary/napi-v8/3.20.0/CPU-windows-3.20.0.zip
npm ERR! node-pre-gyp ERR! install response status 404 Not Found on https://storage.googleapis.com/tf-builds/pre-built-binary/napi-v8/3.20.0/CPU-windows-3.20.0.zip
npm ERR! node-pre-gyp WARN Pre-built binaries not installable for @tensorflow/tfjs-node@3.20.0 and node@16.17.0 (node-v93 ABI, unknown) (falling back to source compile with node-gyp)
npm ERR! node-pre-gyp WARN Hit error response status 404 Not Found on https://storage.googleapis.com/tf-builds/pre-built-binary/napi-v8/3.20.0/CPU-windows-3.20.0.zip
npm ERR! gyp info it worked if it ends with ok
npm ERR! gyp info using node-gyp@9.1.0
npm ERR! gyp info using node@16.17.0 | win32 | x64
npm ERR! gyp info ok
npm ERR! gyp info find Python using Python version 3.10.7 found at "C:\<path>\AppData\Local\Microsoft\WindowsApps\PythonSoftwareFoundation.Python.3.10_qbz5n2kfra8p0\python.exe"
npm ERR! gyp ERR! find VS
npm ERR! gyp ERR! find VS msvs_version not set from command line or npm config
npm ERR! gyp ERR! find VS VCINSTALLDIR not set, not running in VS Command Prompt
npm ERR! gyp ERR! find VS could not use PowerShell to find Visual Studio 2017 or newer, try re-running with '--loglevel silly' for more details
npm ERR! gyp ERR! find VS looking for Visual Studio 2015
npm ERR! gyp ERR! find VS - not found
npm ERR! gyp ERR! find VS not looking for VS2013 as it is only supported up to Node.js 8
npm ERR! gyp ERR! find VS **************************************************************
npm ERR! gyp ERR! find VS You need to install the latest version of Visual Studio
npm ERR! gyp ERR! find VS including the "Desktop development with C++" workload.
npm ERR! gyp ERR! find VS For more information consult the documentation at:
npm ERR! gyp ERR! find VS https://github.com/nodejs/node-gyp#on-windows
npm ERR! gyp ERR! configure error
npm ERR! gyp ERR! stack Error: Could not find any Visual Studio installation to use
npm ERR! gyp ERR! stack     at VisualStudioFinder.fail (C:\<path>\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:122:47)
npm ERR! gyp ERR! stack     at C:\<path>\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:75:16
npm ERR! gyp ERR! stack     at VisualStudioFinder.findVisualStudio2013 (C:\<path>\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:364:14)
npm ERR! gyp ERR! stack     at C:\<path>\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:71:14
npm ERR! gyp ERR! stack     at C:\<path>\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:385:16
npm ERR! gyp ERR! stack     at C:\<path>\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\lib\util.js:54:7
npm ERR! gyp ERR! stack     at C:\<path>\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\lib\util.js:33:16
npm ERR! gyp ERR! stack     at ChildProcess.exithandler (node:child_process:408:5)
npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:513:28)
npm ERR! gyp ERR! stack     at maybeClose (node:internal/child_process:1093:16)
npm ERR! gyp ERR! System Windows_NT 10.0.22000
npm ERR! gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\<path>\\AppData\\Roaming\\npm\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "configure" "--fallback-to-build" "--module=C:\\<path>\\.node-red\\node_modules\\@tensorflow\\tfjs-node\\lib\\napi-v8\\tfjs_binding.node" "--module_name=tfjs_binding" "--module_path=C:\\<path>)\\.node-red\\node_modules\\@tensorflow\\tfjs-node\\lib\\napi-v8" "--napi_version=8" "--node_abi_napi=napi" "--napi_build_version=8" "--node_napi_label=napi-v8"
npm ERR! gyp ERR! cwd C:\<path>\.node-red\node_modules\@tensorflow\tfjs-node
npm ERR! gyp ERR! node -v v16.17.0
npm ERR! gyp ERR! node-gyp -v v9.1.0
npm ERR! gyp ERR! not ok
npm ERR! node-pre-gyp ERR! build error
npm ERR! node-pre-gyp ERR! stack Error: Failed to execute 'C:\Program Files\nodejs\node.exe C:\<path>\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js configure --fallback-to-build --module=C:\<path>\.node-red\node_modules\@tensorflow\tfjs-node\lib\napi-v8\tfjs_binding.node --module_name=tfjs_binding --module_path=C:\<path>\.node-red\node_modules\@tensorflow\tfjs-node\lib\napi-v8 --napi_version=8 --node_abi_napi=napi --napi_build_version=8 --node_napi_label=napi-v8' (1)
npm ERR! node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (C:\<path>.node-red\node_modules\@mapbox\node-pre-gyp\lib\util\compile.js:89:23)
npm ERR! node-pre-gyp ERR! stack     at ChildProcess.emit (node:events:513:28)
npm ERR! node-pre-gyp ERR! stack     at maybeClose (node:internal/child_process:1093:16)
npm ERR! node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (node:internal/child_process:302:5)
npm ERR! node-pre-gyp ERR! System Windows_NT 10.0.22000
npm ERR! node-pre-gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\<path>\\.node-red\\node_modules\\@mapbox\\node-pre-gyp\\bin\\node-pre-gyp" "install" "--fallback-to-build"
npm ERR! node-pre-gyp ERR! cwd C:\<path>\.node-red\node_modules\@tensorflow\tfjs-node
npm ERR! node-pre-gyp ERR! node -v v16.17.0
npm ERR! node-pre-gyp ERR! node-pre-gyp -v v1.0.9
npm ERR! node-pre-gyp ERR! not ok
npm ERR! * Downloading libtensorflow
npm ERR!
npm ERR! * Building TensorFlow Node.js bindings
npm ERR!     C:\<path>\AppData\Local\npm-cache\_logs\2022-09-23T06_19_58_814Z-debug-0.log
Here is logs of node-red on IBM cloud
2022-09-23T06:44:47.480Z Install : node-red-contrib-tensorflow 0.2.2
2022-09-23T06:44:47.990Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict node-red-contrib-tensorflow@0.2.2
2022-09-23T06:44:49.054Z [err] npm
2022-09-23T06:44:49.054Z [err]  WARN
2022-09-23T06:44:49.054Z [err]  config production Use `--omit=dev` instead.
2022-09-23T06:45:06.410Z rc=null
Hi did you find the solution?
No , not yet
If you read the output of the cmd, what do you read ? Especially the lines with gyp ERR! find VS
For windows, when installing nodes that need compiling, the solution is to include the "necessary tools" when you install nodejs
