Problems deleting a group
Do other folks see this behaviour? It seems only to happen after you delete a junction.
NR 3.0.2, node.js 16.19.0
  • Make a group containing inject, junction and debug nodes. Deploy.
Untitled 1
  • Select and delete the junction. Deploy.
  • Select the group. Delete.
    The group and nodes remain on screen.
yes, able to reproduce the problem.
@jbudd it gets weirder in v3.1.0-beta 1
if you add the inject and debug and connect them the insert the junction you have this
Screenshot 2023-02-05 at 4.35.18 AM
if you now select that flow and do a copy, then a paste you loose part of the wire
Screenshot 2023-02-05 at 4.36.33 AM
I've just reported this on the v3.1.0-beta 1 thread
There are other strange effects too but I presume they will all be fixed by some simple change
Untitled 2
Yup, I was seeing weird results too.
