Where did the junction nodes go?
On a mac with safari and 2 rpi's.
When I copy a flow from one rpi to another.
When I copy a flow with cmd e, current flow, my
junction nodes are not included.
When I use cmd a e, selected nodes, my
junction nodes are included.
Does anyone else see the same thing?
ripi80
13 Dec 20:09:06 - [info] Node-RED version: v3.0.0-beta.2
13 Dec 20:09:06 - [info] Node.js  version: v16.18.1
13 Dec 20:09:06 - [info] Linux 5.15.76-v7+ arm LE
13 Dec 20:09:10 - [info] Loading palette nodes
13 Dec 20:09:16 - [info] Dashboard version 1.0.2 started at /ui
13 Dec 20:09:19 - [info] Settings file  : /home/poul/.node-red/settings.js
13 Dec 20:09:19 - [info] Context store  : 'default' [module=memory]
13 Dec 20:09:19 - [info] User directory : /home/poul/.node-red
13 Dec 20:09:19 - [warn] Projects disabled : editorTheme.projects.enabled=false
13 Dec 20:09:19 - [info] Flows file     : /home/poul/.node-red/flows.json
13 Dec 20:09:19 - [info] Server now running at http://127.0.0.1:1880/
rpi85
13 Dec 20:11:25 - [info] Node-RED version: v3.0.1
13 Dec 20:11:25 - [info] Node.js  version: v18.7.0
13 Dec 20:11:25 - [info] Linux 5.15.76-v7l+ arm LE
13 Dec 20:11:27 - [info] Loading palette nodes
13 Dec 20:11:28 - [info] Node-RED FlexDash plugin version 0.4.109
13 Dec 20:11:30 - [info] Node-RED FlexDash version 0.4.109
13 Dec 20:11:30 - [info] Node-RED FD Core Widgets version 0.4.50
13 Dec 20:11:33 - [info] Worldmap version 2.31.1
13 Dec 20:11:34 - [info] Dashboard version 3.2.3 started at /ui
13 Dec 20:11:34 - [info] FlexDash UI version 0.4.63
13 Dec 20:11:34 - [warn] ------------------------------------------------------
13 Dec 20:11:34 - [warn] [smithtek-node-red-tools/splitter] 'splitter' already registered by module node-red-contrib-splitter
13 Dec 20:11:34 - [info] Settings file  : /home/poul/.node-red/settings.js
13 Dec 20:11:34 - [info] Context store  : 'default' [module=memory]
13 Dec 20:11:34 - [info] User directory : /home/poul/.node-red
13 Dec 20:11:34 - [warn] Projects disabled : editorTheme.projects.enabled=false
13 Dec 20:11:34 - [info] Flows file     : /home/poul/.node-red/flows.json
13 Dec 20:11:34 - [info] Server now running at http://127.0.0.1:1880/
  1. what do you mean by a junction node?
  2. Are you coping from the Mac and pasting on the PI or the other way around?
  3. do the jusctions span tab pages in the editor?
  4. I see you releases are old, current is v3.0.2 have you thought about upgrading them?
@Frida - Why have you tagged 'flexdash' in this topic? Is there some reason why you think flexdash is causing the problem?
It is the small squares that connect the lines between
nodes.
I use mac as window for the 2 rpi's. Taking a copy
from one rpi and transfers to the other rpi.
I will update and try again.
I don't know why flexdash is tagged, maybe because
it says flexdash somewhere in the text.
I will remove it if I can.
There were significant changes to junctions during the beta releases so it is probably due to import or export of that NR instance.
Does this happen when exporting / importing between v3+ (non beta) versions?
