Problems with the exec bloc
Hello Everybody :grinning:,
I just found a python script to control my new led matrix the MAX7219
The script is working fine but when i tried to launch it with the exec bloc it send the error : command failed
I don't know how to fix that, please can someone help me ?
My flow :
[{"id":"1c52dee0.05af61","type":"change","z":"ed38ec92.4e1d2","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"\"-c 'rf1(\" & payload & \")'\"","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":180,"y":320,"wires":[["4be02acf.9e1b2c"]]}]
Not seeing where the exec fits with that flow or what you are invoking ?
What does the second output (stderr) show ?
Do you need -u to unbuffer the output ?
Is this a one off command or does the python app expect more input ? in which case the node-red-node-daemon node may be more appropriate as that takes a continuous stream of commands on stdin.
No it's just a timestamp that will be activate if ireceive a message on my phone;
Here are the 3 output in order :
26/01/2019 à 19:49:37[node: 513f2a71.342e2c](http://192.168.0.18:1880/#)
msg.payload : string[0]
26/01/2019 à 19:49:37[node: ff6d8c11.8d04a8](http://192.168.0.18:1880/#)msg.payload : string[186]
"usage: matrix_demo.py [-h] [--cascaded CASCADED]↵ [--block-orientation {0,90,-90}] [--rotate {0,1,2,3}]↵matrix_demo.py: error: unrecognized arguments: 1548528575364↵"
26/01/2019 à 19:49:37[node: f55d01ec.e0cac](http://192.168.0.18:1880/#)msg.payload : Object
object
code: 2
message: "Command failed: python /home/pi/matrix_demo.py 1548528575364↵usage: matrix_demo.py [-h] [--cascaded CASCADED]↵ [--block-orientation {0,90,-90}] [--rotate {0,1,2,3}]↵matrix_demo.py: error: unrecognized arguments: 1548528575364↵"
I'm sorry i dont know what mean unbuffer, I just need to execut my script not to get an ouptput back.
Ok i will try daemon but can you tell me if my command is right, I have found so many different way to execute a script but no one work with me...
the second of those gives you the error message and the problem you need to fix.
You aren't calling the command with the correct arguments... you are just passing it a timestamp
Maybe you don't need the
Ok I just uncheck the append and it works !
Thank you a lot :kissing_smiling_eyes:
